Question about LG enV VX9900 Cellular Phone
This has happened several times--Phone just dies. I put it on the charger display eventually says Charging Complete, but the phone is just dead--no display, can't even turn it on. I've taken it for service before but now I would like to do it myself.
  • LG Master
  • 8,404 Answers
I think your battery is in need of replacement ...
Posted on May 04, 2010
  • A Miller May 08, 2010
    So you dont think it is the battery???
IPhone 5 was working perfectly, but when I plugged it in to charge, it didn't start charging. I could still use the phone. Now the phone died and nothing happens. Is the battery dead (as in broken)?
I would guess that you battery is fine, it is either your charger is not working or worse case your charger socket on you phone is damaged. Try connecting your iphone to your computer via the USB port and charging cable, if your phone starts to charge you know you have a problem with the plug side of your charging cable which is where your transformer is. Be aware that if your battery is totally flat it could take several minutes before you hear the beep from your phone to indicate that it is charging. If that doesn't work it could be your charging lead that is damaged so try charging with a different lead. If still no joy then you could be in trouble as the charging socket is soldered to the mother board and could be an expensive repair so fingers crossed it is only the charger that is damaged.
Jan 02, 2014 | Apple iPhone Smartphone
Battery died while talking, left on charger overnight, still dead, no light no nothing
If its showing charging and the battery is ok but the phone is not displaying or coming up at all then there is problem with the phone . if you can open the phone bring out the board and wash with methylated spirit and sundry then later recouple it back and on with a good battery... but if the problem is that you plug the battery and it did not even show charging kindly make use of a desktop charger to boost it before charging with the charger .or better still look for a good battery to test it on..
kindly rate this solution..
May 07, 2010 | Nokia 6126 Cellular Phone
Lg vx9400 won't turn on, or charge.
how can I fix the charger entrance becuase my phone wont charge
Apr 02, 2009 | LG VX9400 Cellular Phone
Phone completely dead
This is a very odd problem with an even "odder" solution. When this happened to mine, I found a website that told me the following. I swear it works... eventually... probably.
Take the back off and just set it aside for a few minutes.
Now, remove the battery, and then put it back in, and then press the power button. If that does not do it, repeat the process...
... like 20 or 30 or 40 times. Eventually, the unit will make a (scary sounding) "pop" noise, and should turn on as normal.
I have had 3 Tilts. (I tend to be hard on phones.) Of those, two have had the "death" issue. Both were resuccitated this way, and worked just fine afterward.
Best of luck! Hope that helped. :-D
Jun 21, 2008 | AT&T 8925 Tilt Smartphone
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Not charging
i think ur phons circuit is short .so thats why
Nov 27, 2007 | Nokia 5500 Sport Cellular Phone
Charging problem
check the base connection this can be damaged if the charger is inserted the wrong way.
If this has happened then you will need a tech to repair it.
If it is not this then I think your battery has died
Nov 16, 2007 | Samsung SGH-E370 Cellular Phone
Phone says "charge complete" but then just dies
I took your suggestion and replaced the SIM card, but the difference is I managed to locked it in tightly. It worked.
Aug 21, 2007 | Motorola Mobility SLVR L7 Cellular Phone
VX6100
same thing just happened to me a few weeks ago. I took it in and was told its something in the phone, but it could not be fixed. They suggested I get a new phone. What a help that was.
Dec 11, 2006 | LG VX6000
LG enV VX9900 Cellular Phone Logo
127 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
