Question about Bernina Virtuosa 160
I can only sew the first bar of the buttonhole. When I press the securing button nothing happens and the machine carries on sewing the first bar. I just cannot make any of the button holes work. Can I do it manually and if so how?
I can't be specific, but I had problems with my Bernina Virtuosa 160 automatic buttonholer.
Check the feeddog teeth height. At their highest point, the FRONT teeth height should be 0.05mm higher than the back teeth.
Good luck.
Esther. England.uk
Posted on Jul 31, 2010
E2 error code brother sewing machine
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing
Jan 11, 2014 | Sewing Machines
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
When i turn on my sewing machine and press the foot control my machine beeps and e2 error appears
Jun 26, 2011 | Brother CS-6000
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
Apr 07, 2009 | New Home MX-3123 Computerized Sewing...
Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Jun 28, 2008 | Husqvarna Viking 1
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
242 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
