Question about Car Audio & Video
I have a pioneer gm 2200, i dont know how to wire it up to my car, could you help thanks
  • 3 Answers
You should have 4 or 3 wires... cd turn on wire, ground wire, power wire, and last audio input and output wire... to hook the power wire up you would have to lead it going to the power source and make a hole or find one to travel it to the engine from inside the car, then bolt it the the car battery terminal. the ground wire you would have to bolt it to the body of the car from inside the trunk or where ever you have the amp, as long as it is connected to somthing metal! the cd turn on wire you would have to travel it to your (after market cd player or stock) to behind it, into the connecter which should be 16 or 12 and hook it in one of the wire holes! this also goes for the audio input and output wires, connect one end to amp then other behind the cd player! make sure to leave anough slack to b able to connect to amp! hope this has been helpful :)
Posted on May 05, 2010
I have a pioneer gm x334 car amplifier and the power light keeps flashing instead of staying steady. what does that mean?
make sure remote wire is good and tight, also make sure the ground has a solid connection.
If this helps please leave me a rating, thanks.
Jul 07, 2011 | Pioneer GM-X334 Car Audio Amplifier
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
I dont know witch wires are hot or ground on the 6 wire plug
Look on the side of your amp and the one that says gnd or something like that is ground. The one that says bat or something like that is your battery wire. The the one with a small spot for a wire is your signal wire. Other then that i don't fully understand your question
Feb 14, 2010 | Pioneer GM-5000T Car Audio Amplifier
I have a Pioneer GM-X862 when i have it
make sure you do not have the ground and power crossed or touching if that dont work then you have ground problems hope that helps if not your amp is at fault(replace it)
Nov 03, 2009 | Pioneer GM-X862 Car Audio Amplifier
The Pioneer GM-5100T wiring help?!!
i just sent you the manual for your am everything you need to know is in there. i also have tht plug if you need it. but will only be used for high level inputs for factory radio's if you have a after market radio use your rca jacks. or if you want you could use a converter if you have a factory radio that makes speakers outputs from the radiointo rca jack that will go into the amp. the rca'sare the best way it will sound much cleaner. good luck
Sep 27, 2009 | Car Audio & Video
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
Witch wire
i dont know what those 2 wires are for but if the amp cuts on and works just tape the 2 wires seperatley because that amp shouldnt even have those 2 wires
Apr 06, 2009 | Pioneer GM-X324 Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
Car Audio & Video Logo
896 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
