Question about Dryers
I have a Kenmore Elite HE3 electrical dryer. We have moved to Australia, brought our dryer and the electrician is asking for info on the 3-wire connection power supply. There are three wires connected to the machine, Black, white and Red. The white, he said is the Earth wire, but the manual does not specify what the black or red are. He is asking to find out if one is 110v and one is 240 or if they are both 240 - as that will determine how it gets converted over here. We have to get a new socket installed because of the 32 amp requirements. Thanks!
  • 5,911 Answers
Your dryer runs on 240VAC. The white wire is actually a NEUTRAL (no voltage). The RED and BLACK wires should have 110VAC present on EACH one. If your electricain takes voltage readings they should indicate the following:
RED to BLACK = 240VAC
RED to WHITE = 110VAC
BLACK to WHITE = 110VAC
I hope this helps you. Post back if you have any further questions/concerns.
Posted on Mar 26, 2008
  • Dryers Master
  • 13,433 Answers
White, Ground
Red, 240v 50hz AC
Black Ground for 240v
  • Dryers Master
  • 19,396 Answers
Red is phase balck is neg
  • 2 more comments
  • Ginko
    Ginko Mar 26, 2008
    If your appliance is not dual voltage, instead of calling an electrician and eventually replacing parts, you can buy an adapter, like the ones at the bottom of this page. You need to buy an adapter with enough load for your appliance. The small ones will not work.
    Here is an article about voltage converters, that is what you need .
    HERE are voltage converter for australia, this should solve yourproblem .
    Regards
  • Ginko
    Ginko Mar 26, 2008
    And definitively this one will do the job, do not get scared price is in AU dollars, .
  • Ginko
    Ginko Mar 26, 2008
    Electricity in Australia is 240 Volts. The voltage needed change depending on the manufacture of your appliance. If it had been built and bought in UK, red(+) and black(gr., -) wires will be 240V. In the rest of Europe it will be 220V. In USA is 110V, often appliances in USA are dual 110V/240V. Check your appliance manual, or look for specs sticker on your dryer for details on your specific case.
    The best solution in my opinion remains the converter.
  • Ginko
    Ginko Mar 26, 2008
    If you bought the dryer in USA red and black are likely both 110V.
    If your device had dual voltage you would not need the electrician.
    Regards
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
I have a Kenmore Elite HE3 dryer model # 110.8483220. It has no power. We tested the plug and it tests for 110V of power, and the wire connection at the top of the dryer (on the outside) has power. But...
Your dryer is electric. This means it needs 2 electrical phases (hot wires) and one neutral to wor. If you measure 110v across 2 phases - one of them is out.
Unplug the dryer. Find the double breaker for your dryer on the breaker panel.
Pull breaker to the off position hard (do not overdo it,as you can pull the breaker out), and then back to on position.
Check voltage between the two phases, it should read 220-240v. Check the voltage between each phase and the neutral (middle prong), should read 110-120v. If you don't get these readings - call electrician.
If you get the proper voltage, plug the dryer back in. If it does not work - Dryer needs repair. Likely a thermal fuse is blown or problem with power wiring inside.
Oct 13, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Kenmore Elite HE3 dryer whose timer is not working
You will probably have to replace the timer switch.
Most timer switchs are non-repairable.
If you replace the timer switch, make sure you get the right one and then replace one wire at a time, this will save problems if you get confused with the wiring.
Good luck,
I hope this helps
Oct 13, 2009 | Kenmore Dryers
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 electric dryer control panel is not working. When the door is open the light inside is on, but with the door open or closed the control panel above does not turn on or light in any...
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
