Question about Rosieres Accu-Steam Drop-In Electric Griddle - 240V - 24 Cooktop
Oven top is rusting
We have recently moved to a house which has a Bocuse 4040DB installed. the iron warmer top over the left oven continually rusts and stains when items sometimes with steam are placed on it. I s there any way to prevent the oventop and wok burner from rusting or what should I use to clean it.
  • 2,100 Answers
Those iron parts are supposed to be seasoned with a vegetable oil, before they even get shipped, but they can be cleaned, either with a 3m type cloth or bronze wool, Once cleaned, oil them up real good with olive oil, vegetable oil, and do it every day. Then cook something and oil it again, don't wash these parts, just wipe them out and oil them up. had a new stove come on the job once with the griddle some kind of grease like lard on it, but only in one spot, the rest was solid rust!!! We got it cleaned and oiled up. Hope this helps.
Posted on May 04, 2010
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
I just moved to a fully furnished apartment. How do I turn off the schott ceran cooktop. Both knobs are already pointing to zero but one of the lights is still on.
This cook top light may stay on until the heating element has cooled down,
This is a warning that the top is still hot to warn you so you do not get burnt.
Feb 05, 2012 | Cooktops
Seized knob, won't turn
Get some rust buster and apply it to the valve stem liberally. Work the shaft in and out a bit to loosen the shaft. Let that rust buster sit on there a bit. Good stuff.
Sep 27, 2011 | Amana AKS3040 Gas Cooktop
The flame control burners are rusted and not able to increseheat
Spray with a little rust remover fluid and let set for a few minutes.
Jul 05, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Flame too low
Most probably dirty jets. If water was spuilled, there is a possibility of rust forming on some parts. Low flames are usually due to inadequate gas supply, due to dirty jets and burners. Often rust forms on the top burners in the little holes, causing slight blockage - clean the holes with a needle properly and check. Oshie
Jul 30, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Rosieres Accu-Steam Drop-In Electric Griddle - 240V - 24 Cooktop Logo
65 people viewed this question
Top Rosieres Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Rosieres Cooktop Expert? Answer questions, earn points and help others
