Question about Refrigerators
Liebherr 7080 333-02 ice maker is producing water
Liebherr 7080 333-02 ice maker, which is 2 and a half years old, is producing water as well as making ice cubes resulting in a solid mass of ice cubes. Temperature is - 18C as recommended. The ice maker is part of a combined fridge/freezer 7082 532 - 00. Many thanks CB
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
My Liebherr ign 2566 freezer is having problems with the icemaker. It is producing ice cubes but also water is pouring direct into the tray therefore producing a big slab of frozen water.
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Liebherr Refrigerators
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Our brand new 3 door 25' LG has stopped producing ice. The switch is ''on'', and water dispenser works. The motor operates to send either cubes or crushed ice out the dispenser, but NO ICE. What do I look...
LG has problems with there ice makers. if is less than a year old it is under warrenty--even if you dont have a reciept. sounds like the ice maker needs replaced. i have replaced several that were less than a year old.
Oct 28, 2009 | Refrigerators
Blue ice from ice maker
I have this problem too. Seems to be a couple of blue paper washers in the unit that the water filters through and they break up. Ive had this issue go on for more than a year now with Liebherr trying over and over not to claim responsibility. Ive sent them the blue washers and photos and all to get analyzed and they simply do not call me back. Their service center didnt even know there were 2 blue washers in the unit. Seems to be a mess. In any case I still have a very large amount of blue paper dust in my ice and its unuseable. Any solutions?
Oct 01, 2009 | Liebherr KIKNV3056 Bottom Freezer...
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Refrigerators Logo
283 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
