Question about Samsung HP-T4254 42 in. Plasma Television
Broken inside screen for samsung
The problem is that i hit a little bouncey ball on the screen but it tured the screen black and the left hand side of the screne is a cracked from the top to the bottom with green linees through it.What should i do and how much will it cost to get it fixed by a expert?
    Brigadier General:
  • 3,006 Answers
You've broken the plasma screen itself and the fix is to replace it. Unfortunately, it's the single most expensive part of the entire tv by a long way (effectively you buy the screen at a discount and get everything else thrown in for free), and it often costs more to buy the screen than a complete new tv
Unfortunately your only practical fix is to replace the entire tv and to avoid throwing anything against the fragile screen in future. LCD screens are more robust than plasma and also don't suffer the screen burn-in problems which you often get if using a plasma tv with a gaming console. If you choose to go LCD next time, then still avoid allowing anything or anyone to touch the screen unnecessarily. Both plasma and LCD screens are far more fragile than the old glass cathode ray tube tv's.
There are no warranties which will cover this kind of damage, but it may be covered if you have home contents insurance with accidental damage cover if the ball hit the screen accidentally. If you tell the insurer that the ball was thrown deliberately then it's not an accident and will not be covered.
Sorry there's no quick or cheap fix, but I hope that my reply has still been of use. Please take a moment to rate my answer.
Posted on May 04, 2010
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Everytime i hit a little bump my tured sqweaks an it knocks around the front tire. I dont know if its my bearings or ball joint or if i need new shocks. Can some one help pin point the issue.
  1. Shock absorbers (shocks) dampen out the spring motion. Go to each corner of the car and "bounce" the car. If it goes down, up, and stop,s the shock absorber at that corner is OK. If it goes down and up any more than that, the shock is bad.
  2. Jack up one front wheel. Pull on the top of he wheel and push in the bottom, and then the reverse. Back and forth. If it moves much it could be the ball joint.
  3. Rotate the tire slow and listen for a grinding noise and try to see if the wheel is unsteady while turning. If so, the bearing needs to be replaced.
  4. If the bearing seems OK but the tire moved (step 2) you probably have a ball joint problem.
Nov 03, 2015 | Cars & Trucks
My android does not display audio player on front page site
it will most likely be one the next page of applications if you just installed it.
Put your finger on the right hand side of the screen and drag it from the right hand side of the screen to the left hand side of the screen.
Mar 03, 2015 | Samsung T699 Galaxy S Relay 4G T-Mobile...
LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Mar 24, 2012 | LG 37LE5300 LED TV
Can you please help me fix my cell phone it's a samsung recalim and everytime i try turing it on there's just a black screen i just want to know if there's anything i can do to get it working...
Did you hit or dropped your phone? Maybe the screen got broken, if i were you i would take it to a service center.
Also you can try rebooting it from your pc, just connect it and restore it.
Aug 30, 2011 | Samsung Reclaim Cell Phone
Smashed screen
It may still have a warranty try calling the supplier. :D
Feb 17, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Touch screen - left hand side does not work
this sometimes happends if you have knocked the screen a few times.
it also does this when there is water inside it i would recommedn you place it on your heater for 2 hours.
if there is a chip in the screen or the left hand side of the screen is smashed it will not work because the sensors will be damaged
Apr 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung HP-T4254 42 in. Plasma Television Logo
452 people viewed this question
Jerry Greenberg
Jerry Greenberg
