Question about Xincom XC-DPG602 Router (XCDPG602)
I have tried a 'spare' LAN connection in the office but my pc will not connect to the network. Does the port require activating?
The port shouldn't need 'Activated'. If you are trying to connect using a 'spare' port in the wall, the wall socket may need 'patched' in to the network to allow your computer to communicate through it.
If you are connecting directly to the router/switch/network hub, it may possibly be an upload port you've connected to (a port used to connect one hub to another or to the main network). There is sometimes a switch next to the port to change it to a normal port, alternatively try selecting a different port to see if your computer will connect.
Posted on Jan 27, 2011
How can I connect my notebook to another pc without installing LAN??
A Local Area Connection, or LAN, is generally a small home or office network used to link all the devices in the area. With the advent of wireless technologies, LAN networks are no longer limited to the amount of cords you own. Laptops can connect to wireless LAN easily with their built in wireless adapters. Connecting two laptops together over wireless LAN is also easy, but requires a few special steps to give the laptops access to each other.
1Connect both laptops to the wireless network you wish to use. Once connected, click the "Start" button and navigate to the "Network" menu.
2.Click the "Network and Sharing Center" link. Press the "View Computers and Devices" button. A list of devices currently on the network is displayed.
3.Check the list for the names of both laptops. If both laptops are displayed in the list of devices connected to the network, the devices are connected wirelessly to a LAN network.
Sep 06, 2011 | IBM ThinkPad R50e Notebook
I have 10 computers and 2 printers networked in the office. I'd like to hae them all wired. I bought a 10/100 switch but not sure how to hook it up with my router. Any advice?
Most low to mid range switches require no configuration. Switch-to-router connections use a standard straight-through CAT-5 network cable, same as for your PC. Connect any switch port to any LAN port on the router (you didn't say if your router has more than one) and then connect your PCs and printers to the other switch ports with CAT-5 network cables. The WAN port on the router remains connected to the upstream (Internet) provider.
Feb 19, 2011 | Computers & Internet
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
Problem connecting external verizon modem to computer- error msg 'network cable unplugged'
Possible reason why your getting this message are the following.
1. defective ethernet cable
2. defective lan port on the modem.
I would advice you to do the following
1. Try another working cable
2. If your modem has multiple lan ports ( modem/router)
you can plug it on the other LAN ports and see if it will lid up
3.If you have a spare computer to try on the modem , please do so, so you can further isolate the problem . If its a modem port problem or your computer itself
Cheers.
KJ
Jul 04, 2010 | E-Machines eMachines Desktop PC
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
May 12, 2010 | D-Link DP 300U (DP-300U) Print Server
I have a new network printer (Samsung SCX-5635FN) I cant get connection to the printer. I have connected to the LAN port of my router and tried both DHCP and static IP. I have try to change the LAN cable...
have yo installed the printer on to the system ( add a printer ), have you installed the correct driver for the printer
it is not a matter of just connecting leads and expecting it to work
Apr 11, 2017 | OKI C5300n Led Printer
How can i connect to the internet using my switch??
Basically Internet connection required a networking connection for multiple number of PCs.There are 5 types of network connection and most simple and common network connection is Local Area Connection.You can use Windows Xp or Vista for your OS, when connection was made set up your lan from your internet server from cd provided by DSLinternet server.You should Have one PC server for your multiple PC as the administrator.If your inernet was configured from your PC server(as administrator) Share your internet using your LAN in each PC using Windows xp follow set up networking clicking additional task and click Home and office networking then follow wisard set up.You Have now internet connection in your multiple PC.
Feb 24, 2009 | Computers & Internet
Internet connection
plug the modem through the USB cable given to the usb port and install the required driver from the given CD..If usb cable or CD is not given approach the BSNL office and ask for it..Else u can buy a lan card whick cost abt 100 i think..
Sep 28, 2008 | Computers & Internet
Unable to connect properly on LAN
Showing connected only means there is an active cable attached to the network port.
You will need to check the laptop to see if it should have it's IP address assigned manually or is being assigned by the router/hub in your network using DHCP.
Hope that helps.
Apr 09, 2008 | Computers & Internet
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Xincom XC-DPG602 Router (XCDPG602) Logo
32 people viewed this question
Top Xincom Computers & Internet Experts
David Payne
David Payne
Are you a Xincom Computer and Internet Expert? Answer questions, earn points and help others
