My Sagem DLP HTD 501, recently came up with a warning light error,too replace the lamp,and subsequently blew.I replaced the lamp,but still have the same problem,with the screen dead and the warning light still on .Any suggestions.......Steve
Ok...this is only a theory. Did u replace bulb..or lamp unit?
To cut along story short the tv has a timing device in it set to about 8000 hours. When u look at a picture (google) of the new replacement lamp unit, there is an additional circuit board on the housing, this aligns to two tiny contacts inside the tv. (you can see it when u look inside the socket. its green and about 10mm by 20mm and labeled lamp saftey). this circuit board (on the lamp unit) is absent on the one that comes with a new htd501. I believe the replacement lamp housings circuit board is a 500Ma fuse, which momentarily sends a current to reset the timing device then immediately blows, leaving your timing device reset to 0hrs.
As i say this is only theory based on reading other materials online, however my friend has this problem and i am waiting for him to give me the go-ahead and try it.
What I will do is make a plasic board with bean tin contacts aligned to the contacts inside the tv, and solder a fuse housing to the home made contacts and use a 500ma fuse. this should reset the timer!!
I cannot guarantee or even recomend this unless u r sure and confident about making the above gadget. however i will return to this page and tell u if i was successful in a week or two.
Posted on Jul 07, 2008
  • pooky72 Jul 07, 2008
    http://www.hifi-forum.de/viewthread-132-..." target="_blank" rel="nofollow" >Translated version ofhttp://www.hifi-forum.de/viewthread-132-...
    It is NOT a fuse (well... maybe a special fuse) but a resistor!
    temporarily put the specified resistor across the contacts i mentioned as per the instructions at the German site above.
    Thats what i am about to do now. Will let u know if i have success.
    OK I have done it!!!!!!!
    simply solder a resistor (value 470 Ohms) across the contacts,
    then put the bulb and housing back
    then screw the black front plate on
    switch on tv as normal
    wait for light to turn green
    switch off tv
    timer is now reset
    take all the above apart again!
    remove the resistor
    put it all back together again
    your tv is now fixed!!!!
    let me know how you got on
    Nick_pook@yahoo.co.uk
    ---!!!GOOD LUCK!!!---
Sagem used two methods to reset the lamp timer.
HTD501 is as described above, with a resistor.
Subsequent models have a fuse mounted in the lamp holder. Whwn the lamp is replaced the fuse should also be replaced. When you first switch on it will blow deliberatrely resetiing the counter
Posted on Jan 17, 2010
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
Apr 25, 2015 | Panasonic Televison & Video
Orange light came on replaced the bulb after a day it blew out then replaced bulb again blew out now the light is red please help
It sounds like it is not getting enough cooling. Clean the cooling paths. I am just taking a guess as I am not familiar with this unit.
Jun 16, 2014 | Toshiba 72HM195 72-Inch Diagonal...
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
My TV shut off recently and just before it shut off I got an error warning that something was wrong with the airflow. Now it won't turn n and it keeps flashing yellow. Someone please help!
first things first. is this set a dlp or a lcd if either it will have a projection lamp and when the filter for air intake gets clogged with dust and dirt it will cause the lamp to fail before its time is up.. have the lamp replaced by a tv service man..goodday.. p.s. expect to peel off about 300 skins..
Nov 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Televison & Video Logo
1,752 people viewed this question
Top Televison & Video Experts
