Question about Brother MFC 7420 All-In-One Laser Printer
How do I scan documents from my Brother MFC-7420 to Adobe on my computer? It keeps scanning as picture and when I try to open or save document in Adobe, it tells me that it is not supported. Thanks
alfi819
  • 65 Answers
SOURCE: does the mfc 7420 scan legal size docs?
Yes. You could look at the printer specifications.
Posted on Mar 27, 2009
  • 133 Answers
SOURCE: Solid black line down the document when scanning
are you using the autofeeder to feed your documents?
if yes, open the top cover and clean both glasses (big and small).
and take the drum out, move the blue panel to clean up your drum.
after that should be working fine.
Posted on May 22, 2009
tommya300
  • 724 Answers
SOURCE: I am using an HP
Well once you have digitized all the documents can they all be converted to PDF?
THen all you need to do is to make sure the titles are in numeric order as page 1 - whatever
Adobe PDF acrobat professional lets you place them all into one doc.
On the left open page options at the top of this menu you can insert after of befor all the rest of the docs just open the lead doc and then add pages to thea you will build a book
Posted on Jul 27, 2009
  • 51 Answers
SOURCE: Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Posted on Sep 14, 2009
  • 159 Answers
SOURCE: Can't scan to PC with Brother MFC 8840D
My guess is a driver problem. I'm assuming you can print to it, so you know the USB connection is good. And you can make a copy (I assume), so you know the scanner mechanism and its connection with the rest of the machine works.
The scanner driver is separate from the printer driver. It's entirely possible to install and use the printer without having loaded the scanner driver. Best bet is to unplug the unit from your computer, then uninstall it completely from Windows. There may be an Uninstall program listed under Brother in your Start menu...All Programs... Or go to Start...Settings...Control Panel (or however your version of Windows get there) and open your Scanners and Cameras folder. If you find the Brother machine in there, Select it and click Remove. Do the same in the Printers folder.
Don't plug your machine back in until you have reinstalled the drivers. Go to www.brother-usa.com, and in the Service & Support box on the right, click Downloads. That will take you to a page where you'll select Multi-Function as your Product Group, then the model.
You'll get two lists of links. Forget Manuals, look at Drivers on the right.
Under Type of Software, click ALL. Select your OS.
You'll get a list of drivers and utilities for your model. Select the Full Package. Brother makes you accept the Terms of Use, then starts the download.
Look for Setup.exe in the main directory, or you may need to browse folders labeled with different language abbreviations to find it.
Start the installation, and don't plug your USB cable in until the computer tells you to. it will install the printer first, then return to install the scanner. It may require you to restart Windows more than once. Sorry.
Once you've suffered through all that it should be fine.
Posted on Dec 24, 2009
Brother 8460 n contol center 3 instructions
Scan the document and save the image as a jpg file. Open your email program and create your message and attach the scanned image file to the email.
Mar 22, 2013 | Brother MFC 7420 All-In-One Laser Printer
Need to scan a multiple page document into a pdf. Every time i attempt to do so, it scans each page and creates an individual file per page.
You must get an Adobe program to do that... OR combine them later. Adobe Professional 8 will allow scanning multiple pages into a document I use it all the time. There are also other PDF makers/converters too, to download. Another way is to scan into Word, or similar, and then "Print" as a PDF.
Mar 03, 2010 | Brother MFC-7420 Printer
I have a printer brother mfc-7420 but i cannot scan my documents so i can attach to emails. can you please give me a solutions.
You must have the Brother printer control center installed on the the computer you wish to scan to. If you do not have the original software disk that came with the printer, you can download it from the brother web site (www.brother.com).
Feb 08, 2010 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 Printer wont scan
We are having problems on scanning documents with our MFC-7420 Printer to send to email?
Jun 23, 2009 | Brother MFC 7420 All-In-One Laser Printer
May 11, 2009 | Brother MFC 7420 All-In-One Laser Printer
Can't scan multiple pages into 1 document
Be kind m'53. Maybe you can scan to a folder, then use print setup to compile all the data on one page, if it's not much data. You'll have to do all this with the computer, don't expect the scanner to do that. There is always lots of software out there to do this kind of stuff.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
I can't scan
When scanning documents on my MFC 7420, this is what I do. Place document on th scanner bed and don't press any buttons, leave it whatever mode it is in. Go to the computer and click on start> program files> scansoft paperport> open paperport se. When paperport is open click on the scan icon in the upper left corner. A dialog box on the left hand side will ask what you want to scan a picture or document. Select accordingly and press the scan icon.
A new window will pop up and ask what you want to scan and the size. You can either select pre scan or scan. The computer then will send a scan request to the scanner. When it is done scanning close the second window that popped up and the document that you just scanned will be there with a red box around it. Click on the document and it will open, then you can edit and save as needed.
Happy scanning
Hatter1
Jan 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
How do I scan a document with a MFC7420 & make it e-mailable?
I called Brother technical support and they walked me through the configuration and device settings. Can do it fine now.
Thanks, Carole
I have a brother mfc-7420 flatbed and am trying to scan multiple pages through the automatic feeder but it only scans whats on the flatbed? Is the feeder only for copies and not for scans? Anything i can...
First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
Now u will have new Window "Scanner and Camera Wizard" click Next
On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
Dec 02, 2008 | Brother MFC 7420 All-In-One Laser Printer
Problem with scanning documents through feeder
you can scan only one doc at atime on this machine.
Nov 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
123 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
