Problems restarting laptop
Our laptop shut down and we ncasn not restart it after following all the suggested steps we still have had no luck
  • 3 more comments
  • Anonymous May 25, 2008
    I have the same problem. at first the computer were shutting down by itself when moved on the table or the support on which it is. Now i can't shut it on at all.I am still trying without success i need help please.
    itself when moved on the table or the support on which it is.Once in a
    while it gets on but it is quit inconstant. Now i can't shut it on at
  • Anonymous Jan 24, 2009
    windows xp professional: d676q-2kkp72fb39ygykv4pxd
    the computer says to restart everytime and got a virus problem
  • Anonymous Apr 13, 2009
    after checking & flashing new bios, reseating the ram modules & HD that doesnt really helped, i tried checking the cooler grill & i found out that it was blocked by dust. the air are not sufficiently flowing out. the processor almost overheated that prompt the system to automatically shuts ddown to prevent further damage.. clean it with compress canned air. dont forget to remove the battery first. i hope that would help you.
  • 26 Answers
What type of unit it is , and how does shut down, CHECK YOUR AC ADAPTER , REMOVED BATTERY FROM UNIT, USED ACADAPTER BY IT SELF
Posted on Mar 26, 2008
  • Yves Morency Mar 27, 2008
    I would like to known the make and model of your laptop, and posible serial no.
How do i reboot my toshiba laptop?
Procedure to reboot your Toshiba laptop may vary depending upon which version of Windows you are using. Refer to the steps below that match your Windows version:
For Windows 8:
If there's a Power icon on your Start screen, tap or click it, and then tap or click "Restart". Else, follow the steps below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Tap or click "Power", and then tap or click "Restart".
For all other Windows versions:
1. Click the "Start" button
2. Click the arrow next to the Shut Down button
3. Click "Restart"
OR
1. Click "Start" button
2. Click "Shut Down"
3. Select "Restart" in the drop-down menu below "What do you want the computer to do?"
GuruAid.com
Jun 25, 2014 | Acer Computers & Internet
Computer syuck in safe mode.
1) If you have made the computer run in the Safe mode, it should automatically shut it down when you restart your computer.
2) If the Restart does not help, then there's a problem with your Windows installation.
I sure hope it's not like in 2 second step! Good Luck!
Jan 09, 2013 | Acer Aspire Computers & Internet
I downloaded a game from GH which I played but once I shut down by laptop and tried to restart the next day I noticed the graphics were greatly enlarged and the laptop shut down. Now when I try to start...
hi
before starting windows press f8 then safe mode
when windows started chang the resulotion to lower mode and restart
if still the problem safmode - uninstall vga driver > restart > install vga driver again
by
Nov 02, 2011 | Dell XPS M1530 Laptop Computer PC...
OmLaptop restarts after being shut down Its a Dell 1545
Hi 1940miker...
Try this solution to your problem
Your computer is set up by default to auto start when a problem occurs.
The computer is configured to automatically restart when Windows stops responding.
To view this setting, follow these steps:
Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
Under System Failure, view the Automatically restart check box.
If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Please take time to rate me
Sep 04, 2011 | Dell Inspiron 1545 Notebook
Restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at info@custompcrepair.org
Mar 16, 2011 | Microsoft Windows XP Professional
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Cannot shut down
I want you to try this first reset the CMOS bat , put a new Hard disk install EXP .
good luck
Dec 19, 2009 | Acer Aspire 4930-6862 Laptop
Keeps coming up with configuring updates stage 3of 3 0% complete do not turn off your computer then it shuts down and comes back on again
Please use this solution thta I have placed on this forum.
Please follow exactly these steps then you computer should be working again.
I have used the following solution.
Restart computer.press f8 then choose option restore computer.
choose option open command.
type: prompt winsxs (press enter)
type: move C:\windows\winsxs\pending.xml text.xml (press enter)
type: exit and restart computer.
Computer should be working again.
good luck.
hope it works for you.
pieter.
Oct 17, 2009 | Dell Inspiron 1525 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
