Question about LG Flatron L1919S LCD Monitor
Power button stuck after monitor fell and will not turn on any help for this.tried eveything
  • 732 Answers
Christina653, If the ON/OFF button is now loose, you or qualified monitor technician will need to open and inspect unit for internal damage to the printed circuit board that the switch is soldered to. You can see some of the typical "tactile switches" that may or may not be inside your unit by visiting www.jameco.com on page 97 of their current catalog.(web code QBF) They and other vendors carry a wide selection to choose from. And this is a case where exact size and style matters. Hope this helps. 12fixlouie
Posted on May 04, 2010
Power button fell inside monitor How do I fix it?
If this is a mechanical button with a two point connect, a small wire can be bridged across the points and resolded in place. Rather than using a power bar, a lamp cord switch can be attached to the cord and turned off and on.
Mar 07, 2012 | Computers & Internet
The power switch seems stuck. It does not move at all. Will not turn on monitor.
The humidifier may have raised the humidity level enough to liquify the accumulated grime and cemented the buttons in place.
Dec 29, 2011 | Apple Cinema HD Display30" Flat Panel...
Hi , My monitor (Philips CRT monitor 109B50) keep showing the phrase 'LIGHTFRAME ON LIGHTFRAME OFF' why is it so? Lastly the blue configuration box with language/zoom/adjust ,eveything ... kept...
It would appear that the control panel buttons are either stuck, or malfunctioning all together. You could take a pen knife and gently lift the buttons and see if the issue stops.
If it does not then your monitor is malfunctioning and will need to be replaced. I would verify your warranty as most monitors carry a 3 year warranty.
Jun 25, 2011 | Gateway FPD2275W LCD Monitor
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Stuck power button on Dell Monitor
Guru Kenny G, There are thousands to choose from in the DigiKey catalog, both through-hole and surface mount types. You should be able to measure the dimensions and order one that will work. Also try
Jameco and Newark Electronics. 12fixlouie
Mar 22, 2010 | Computers & Internet
Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Jun 17, 2009 | Dell E176FPC Monitor
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
LG Flatron L1919S LCD Monitor Logo
131 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
