Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Burning smell from treadmill
Took the cover off and saw that the motor control board has a blown component
The baord model number is AL20RPB048, doesw anyone know where ican find a replacement, the treadmill is a SCFT202.
Thanks
    President:
  • Life Fitness Master
  • 832 Answers
Get a hold of National Gym Supply @ 1-800-496-7278 They can either repair or exchange the board
Posted on May 05, 2010
Why does my ironman 220t treadmill say si2 and give off a burnt scent after replacing a motor control board?
If you wish to get some details About treadmill repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Ironman 220t Motor Control Board Part...
Was running and motor just stopped i bought it new so know it hasnt been used much
you should be covered by warranty if it still new.
If you know the brand, model you can perhaps look for the service manual to look for fuse, blown components or a spare part.
Apr 22, 2016 | Exercise & Fitness
Electronic control board turns on but motor doesn't run all of the time
Hi Eric, sounds like a bad connection on the motor control baord or a sensor watching the front roller or motor spin speed could be dirty. If you need further help, you can try jatinah electronics. Good Luck.
Jan 15, 2015 | Nordic Track Nordictrack Exp1000x Rear...
I have Merit 710T that has recently begun to smell. I have lubricated the belt and had some problems readjusting the tightness and alignment but now that its aligned the treadmill gives me about 30 minutes...
see the video attached, lube TOO the rollers bearing front +back.
see the video how to adjust the deck belt.God bless you
However if finally the problem persist, test the input voltage motor see my personal TIPS, if there are Voltage at the terminals, the motor is faulty. Measure the output Voltage from the control board
for to input to the Motor, if there are NOT voltage from output the control BOARD is faulty, replace.
Oct 07, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a Proform 545s treadmill with incline and with ifit. When i start the treadmill it will no longer attain the programed speed. The higher the speed programed the fast the treadmill will go; however,...
It sounds a lot like it might be your Motor Control Board. You can find one used on varios websites (ebay if you're lucky). I found one for $149.00 on the following website:
http://www.treadmilldoctor.com/PROFORM-545S-TREADMILL-Motor-Control-Board
I hope you got a good deal on it because it seems to be quite an expensive part.
Thanks and good luck!
Mar 21, 2011 | Proform Exercise & Fitness
Pro form 835qt stops working after a few min. Took off cover and it smells very hot in the control section. What looks like a transformer seems to be putting out the most heat. any ideas?
that part is on the incline motor if that is hot and you are not inclining then something is wrong with the incline motor or the controller board
Mar 10, 2011 | Proform Exercise & Fitness
DEAR FRIEND..OUR TREADMILL SA 1060..1.8HP STOPPED WORKING ALL OF A SUDDEN AND WE PRESUME THE MOTOR HAS GOT BURNED AS THERE WAS A BURNING SMELL EMANATING SOON AFTER IT STOPPED RUNNING..WE LIVE IN ABU...
An visual inspection must be made under the motor hood. First unplugged unit then remove motor shroud clean any dirt or debris.Then check for any visible signs of burning on the Motor Control Board. Also check in the front where the power switch is, that may have burned if not, there should be a main fuse holder that also could burn or fuse may have opened up. If the fuse holder is good then proceed to the fuse if it has opened up replace the fuse. Then plug unit back in while you are look at all components while someone initiate start-up and if any burning is visible then isolate what component is burning or arching. Then go to Sports Art Fitness.com go to customer service and get their international number and they should be able assist you.
Feb 27, 2010 | Exercise & Fitness
It has stopped and smells like a motor is burning comes up with error 1 Its a york Barbell treadmill and is model number T-406 LA
Ok! how I say, just send your motor DC to repair, at the same time, check the engine controller. any diode or mosfet is bad or damage
Feb 04, 2010 | York Barbell Home Use Fold-Up Treadmill
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
551 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
