Question about Microwave Ovens
How to replace Zanussi microwave zmc30stq bulb
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my zanussi zmc30stq 1000 watts
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Bulb ZMD30STQX change
Some microwaves have a small square door on the left side, some clip shut, or screw removal. If not! you will need to remove the top "unplug first" bulb is located on the side or back.
Mar 15, 2012 | Zanussi ZMD30STQX 900 Watts Microwave Oven
Hi i need a function switch for a Zanussi ZHC914 rangehood, are you able to help
might have to get from zanussi..........i don't know of a generic replacement.........meder's tv service
Aug 31, 2011 | Zanussi Microwave Ovens
Can't get in to change the bulb
You normally have to remove the outside cover to access the bulb. once you have the cover off you will see the bulb to be able to change it.
Make sure that the oven has been unplugged for a few hours before opening the covers.
Feb 06, 2011 | Zanussi ZMC30STQX Convection Microwave...
My zanussi zmc30stq 1000 watts convection / microwave oven is broken. The convection aspect of the oven is not working, all other elements are but this bit seems not to be heating up. Is this a...
Basic
heatman101
Dec 28, 2010 | Zanussi ZMC30STQX Convection Microwave...
Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Dec 03, 2009 | Zanussi ZMC30STQX Convection Microwave...
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
INTERNAL LIGHT
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Aug 06, 2008 | Zanussi ZMC30STQX Convection Microwave...
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
