Question about Intel D945GNT Motherboard
My intel motherboard is powering but it is not coming on. when i press the power button, the cooling fan rolls for less than a second. what could be wrong with the board?
  • 1 more comment
  • d_orabe May 04, 2010
    there was no beeping sound when i powered it. yea, i plugged all the necessary cables, also placed in the memory, CPU, power supply. i also plugged the 2 set of wires that goes on the motherboard
  • d_orabe May 07, 2010
    i have done that already. still the same result/ outcome.
    thanks for your suggestion.
  • jkpf May 11, 2010
    Was there any beeping sounds when you power up the motherboard? what else did you plug into the motherboard? memory?, CPU?, Hard drive? Power supply? There is 2 set of wires that goes on the motherboard from the power supply, did you plug both of them in?
  • 59 Answers
Please clean the duster of your cooling fan
Posted on May 05, 2010
Recently I cleaned cooling fan of my Toshiba L300 laptop. When press power button to start, fan runs few seconds and stop. Is his normal or any other problem? I dont know how it work originally before the...
the fan is used to keep the motherboard cool. if the motherboard dosnt reach a high tep the fan will not kick on. it's a good thing. means motherboard is staying cool.
Oct 26, 2013 | Toshiba Satellite A135-S2276 Notebook
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
Intel D945GTP power comes for one second and suddenly off
open the tower/ ATX cabinet and then check the two small power cable pins that connects the power button on the ATX cabinet and the motherboard, remove the same from the motherboards end (make sure you note down from where you removed the 2 power pins and then using a insulated screwdriver short the power pins on the motherboard for a second until you see the power coming on let go of the pins as soon as you see the CPU fan moving if it stays on and works normally it is a faulty power switch on the ATX cabinet and then you can either replace only the power switch or get a new ATX cabinet to fix it
you can also check if motherboard stays on if you remove the RAM chip from the motherboard. if yes its a faulty Ram and replacing the same should do the trick
you can also try cleaning the dust accumalated under the CPU fan and between the heat sink as some motherboard cuts off the power depending on the temperature
also if nothing works you can try using a different power supply unit to see if that's the case,
if still no luck then its time to buy a new motherboard.
Feb 06, 2012 | Intel D945GTP Motherboard
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
I started setting up an intel d865perl today and i'm pretty sure i did everything right, i followed diagrams read manuals and such but when i plug in the power cord it immediately starts and there a green...
1. There is a BIOS SETUP setting to "automatically start after a power outage" -- this is useful for "servers".
2. If you press and HOLD the power-button for TEN seconds, the computer should shut itself off.
3. Turn the computer off, disconnect the "data" cable to the HDD (hard-disk-drive) and then turn the computer on. Does the HDD lamp still light-up?
4. Do you get any on-screen video when it starts to start-up?
Sep 02, 2010 | Intel D865PERL Motherboard
Power On, Fans start but stop in few seconds and that's all
May be there is a problem in the windows, but suppose it is not booting at all.
First Check once more your boot options from bios menu
Second If it still the same thing, extract your battery out of your laptop for 12 min, then try to power up your laptop pluging in your power cable(don't use your battery)
Third If it still not working, there must be a problem in your cooling fan, so check it, also check your motherboard & your graphics card (Most of this problems happens due to a problem in the computer cooling system in motherboard & graphics card)
Hope it works for you Christos
Jan 30, 2010 | Toshiba Satellite P200-0TD00Y Notebook
PC won't power on
Try this,Unplug the power cord and hold the power button for 30-45 seconds,plug back in and start computer,if it fails to start,you may have a bad processor.
Aug 02, 2009 | ASUS Intel 5000P Chipset...
Need help wiring Intel Desktop Board D915PGN motherboard
Here you go. Address this manual for your system board from Intel's site, checking and double checking your connections.
http://download.intel.com/support/motherboards/desktop/sb/c6413602_en.pdf
Most commonly it is a disconnected CPU Fan or Chassis fan.
Let us know if you need more assistance, we shall continue to help you troubleshoot.
Apr 17, 2009 | Intel Desktop Board D915PGN - Motherboard...
Powers for 2 seconds
sounds like a heat problem, i.e. cpu overheat, check cooling fan.
Sep 15, 2008 | Intel D915GAV Motherboard
Not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
Nov 29, 2007 | Intel Motherboard
Intel D945GNT Motherboard Logo
141 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
