Question about Apple iTunes
I have moved my iTunes library from C to D drive due to space -and updated the location in iTunes. However, items I purchased prior to moving no longer sync, despite being located correctly. Several items - whether purchased or not - now have ! ahead of their listing and some of these don't play at all. New purchases are fine. What have I done wrong?!
    President:
  • 1,285 Answers
Update to newest itunes version setting the library to d....(do not delete old itunes) the update will do this while also moving and saving settings
Posted on Jun 19, 2010
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
Tip
ITunes library on a new drive
If you have the two files iTunes.itl and iTunes Music.xml, you can trick Itunes into seeing your new library location when you move it to another drive.
Start with iTunes closed.
1. Copy the two files to a safe location.
2. Hold the Shift key down while opening iTunes
3. Tell iTunes to create a new library and locate it on the new drive.
4. Close iTunes
5. Copy all the music files into the new drive and iTunes folder
6. Copy the two files from the old location over the newly created iTunes files in the new folder.
7. Open iTunes
8. Check the music for playability.
This method will save you hours of importing time.
on Dec 07, 2009 | Computers & Internet
How to download music on to my i-pod
Downloading music from your hard-drive to you Ipod is done with the program called Itunes. This program comes with your Ipod purchase or can be downloaded at http://www.apple.com. The software is vital because it not only allows you to purchase from the popular Itunes music service, it's also the only way you can transfer songs onto your Ipod.
So let's look into the Itunes software, and more specifically, the Itunes library that is used to transfer songs from your hard-drive to your Ipod. You'll find it on the left hand panel of the program. Your library contains all your songs, movies, and podcast that you want to transfer over. Through the Itunes library, you'll be able to use their drag-and-drop feature for easy and fast transfer to your Ipod.
Before we move one to the next step, it should be made clear that songs that are downloaded from P2P clients might not show up on the Itunes library. You must add them manually, because you will not be able to transfer any songs until they are integrated into your Itunes library. Doing this is simple. Click on file>add file to library, locate the file you want to add, and press enter to complete the process. There is also the 'add folder to library' function which allows you to transfer a whole folder of songs into the Itunes library. This is quite handy to have if most of your songs are stored in one place on your hard drive.
Alright, let's get back on track here. You know the proper steps in which to keep your Itunes library updated now, and the last step is a breeze. Plug in your Ipod to the USB port in your computer, and you'll notice the new option to add songs from your Itunes library to the Ipod. Click and drag your files into the Ipod transfer screen and then you're done! You're now ready to explore the wonderful world of music without the burden of a large cumbersome computer to haul alongside you!
Sep 19, 2010 | Computers & Internet
I just purchased songs and they wont play on my pc. oher music still plays.
You may need to move them from the Purchased area in iTunes into your iTunes Library. Try the following:
1. Open iTunes.
2. Select the Purchased icon located under Store.
3. Press either Ctrl A (on a PC) or Command A (on a Mac) to select all the songs within this window. Alternatively you can
  • Depress you Shift key whilst you click each song. OR
  • Depress your Ctrl key (PC) or Command key (Mac) whilst you click each song.
4. When the songs are selected, use your mouse to Click & Drag the selected items into your iTunes library or a folder within your library.
I hope this solves your problem. Regards,
Feb 10, 2010 | Apple iTunes
Can't transfer items to hard drive
Go to the Iomega Web sight and find tech support or Manuals/Guides and go from There??
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
IPOD how to move music
hi,
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Step2
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Step3
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Step4
Hit "OK" and click "Apply Preferences."
Consolidate Music
Step1
Move all your music to one place to make the transfer easier.
Step2
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Step3
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Step4
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Step1
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Step2
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Step3
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Step4
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Step5
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Step1
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Step2
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
Step3
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Step4
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Step5
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Dec 15, 2008 | Apple iPod nano 3rd Generation
Error message when I try to play a cd,dvd or rip
Before we try blaming a faulty cd/dvd unit lets check out faulty Windows Media Player Software. Is Media Player up to date? Try installing iTunes set as default. That will force the cd/dvd association to iTunes. See if the player works or what the error is...If it works...Then re-open Media player make it the default again and see it what it does. or This is from the Microsoft site: Windows Media Player cannot find the file. This error message usually indicates the link from an item in Media Library to its associated digital media file is broken. Items in Media Library are links to digital media files that are stored on your computer, a network drive, a removable storage card, an Internet server, or another location. Links can be broken for one of the following reasons: * A link to a temporary file from the Internet cache (for example, a file from the Temporary Internet Files folder) was added to Media Library and that file was later deleted. * A link to a digital media file was added to Media Library and the file was later deleted. To repair a link Do one of the following: * If you deleted or moved the file, replace it to its original location. * If you moved the file, right-click the item in Media Library, click Error Details, and then enter the new location of the file. To delete a link Do one of the following: * Right-click the item in Media Library, click Error Details, and then select the Remove file from Media Library check box. * Right-click the item in Media Library, and then click Delete from Library. Good Luck, Tim
Feb 04, 2007 | HP Pavilion zv5034US Notebook
How do i free up space on my start up disk?
your problem is the space is it?i think on top of moving your itune library u should move all other less important files to any external storage and see whether this will solve the problem.
Sep 05, 2006 | Smartdisk - Peripherals - HARD DRIVE,...
Apple iTunes Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
