Question about Nokia 6300 Cellular Phone
Phone got a tiny bit wet. No usually just two
Phone got a tiny bit wet. No usually just two blue lights either side of phone come on, but nothing else. Very ocassionally it fires up properly for about 5 minutes before it dies again. Is it terminal?
  • 450 Answers
Take apart the phone and take out the mainboard and soak it in isoprophanol to dissolve oxide/corrosion.
use a soft toothbrush to wipe off dissolved oxide.
rinse with plenty of isoprophanol to clean the mainboard properly.
let it dry, mount the phone and it will work again.
Posted on May 11, 2010
Transfer contact list from samsung cell phone to blue tooth in 2004 ls430 Lexus
There should be a tiny 1/4 inch square SD card inside the phone, usually inside or under the battery compartment.
Just transfer this card to the new phone.
This only works if you have put the contact list phone numbers ON the SD card and NOT on the phone memory.
Dec 06, 2007 | Cell Phones
My nokia 6300 has a blue light on all the time on both sides of the phone.How do I switch it off
my Nokia 6300 got wet and now both blue lights are showing and the phone will not turn on?
Jul 15, 2009 | Nokia 6300 Cellular Phone
My BB Curve got wet this past weekend and now when
Place your Blackberry into a plastic bag with a half of a cup of uncooked white rice.
The rice will help absorb moisture from the inside of the phone.
Leave it there for a few days and try it again .
don;t use the phone right now at all, putting power into a wet phone can and will make it worse,
take the battery out and do the rice thing.
if you have a week wait a week and remove it from the rice.
Good Luck and Thanks for using FixYa
Jun 16, 2009 | Cell Phones
Blue green red white squares on frozen screen
The exact same thing just happened to me too! Tried soft and hard reset. Nothing.
Jun 03, 2009 | Palm Treo 700p Smartphone
Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
May 14, 2009 | Samsung SGH-G600 Cellular Phone
When your phone gets wet.
If your phone ever gets wet, DO NOTHING until it drys. If you let it completely dry before trying to use it again, it should work just fine. it's when u turn the phone on when it's wet that ruins it.
Aug 08, 2008 | LG CG225 Cellular Phone
My Z3 got wet...
can you send me a code so i can unlock my phone
Apr 25, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Mar 02, 2008 | GoVideo VR3845 DVD Recorder/VCR
Buttons won't work
Did you get it wet....that usually happens when the phone has been wet.
Sep 15, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Nokia 6300 Cellular Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
