Question about Nikon D70s Digital Camera
My Nikon D70 won't actually take pictures. The letes CHR appear in () in the bottom right hand corner of the LED screen.
    Brigadier General:
  • 3,006 Answers
This is usually an age-related issue caused partially by poor design/assembly of an internal ribbon cable which connects the CF card plug within the memory card slot to the camera. However, the code also indicates either a poor memory card or a poorly seated one, so before looking at more serious causes try giving your CF card a wiggle and also try another CF card to see if there's any improvement.
You have two choices:return the camera to Nikon for repair (usually it's a fixed fee repair and far less than the cost of camera replacement) or you can do it yourself if you're familiar with general simple electronic repair principles such as knowing to wear an anti-static wrist strap. If you make a real hash of the DIY attempt, then Nikon may either charge more than the standard fee or will refuse to attempt a repair and will charge you for the investigative work only and to ship the camera back to you.
There's a Japanese website which shows how to repair the internal hardware problem, the pictures are clear but it's not much use if you cannot read Japanese. If you click here you'll be taken to the original website, and if you click here you should be taken to a Google translated version. You may need to view the link using the FireFox browser with the FoxLingo translation add-on (all at no cost).
Note that the ribbon connector in the pictures may be one of two types. One of them unlocks the ribbon by sliding a couple of catches on either side, the other works by flipping a broad section across the top upwards. Once the cable is unlocked you can remove it and then squarely replace it again locking it back into position. Often this action alone will fix the fault. The sixth picture (single red arrow with Japanese text) points to a foam block which is supposed to cushion the cable and isolate it from strain. Sometimes it's too tight and slowly pulls the cable out of it's seating, sometimes it's too loose and allows the cable to flex a bit every time a CF card is removed or replaced and other times it's broken down into a sticky corrosive goo. Note that sometimes you'll find that the ribbon cable has cracked and broken one or more of the electronic tracks. If this is the case then you'll need to order spare parts and will need to disassemble your camera further to fit them. Nikon will usually include this within the fixed fee repair if found to be necessary.
Posted on May 04, 2010
What is cf card unit?
The camera is having trouble accessing the memory card. Try cleaning the contacts, both on the card and in the camera, and/or try a different card.
Jul 18, 2012 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon 50 says CHR
I found a seemingly do-it-yourself solution in an internet: http://translate.google.com./translate
The site is written in Japanese. It states the FOR/CHR error is caused by loose connection between a circuit board at the bottom of a body and a flexible cable that is connected to the CF card connector. 3rd, 4th, 5th, and bottom pictures from top show how the flexible cable is bowing upward immediately next to the connector and is giving undue pressure that makes bad contact (but it is hard to tell in my eyes). The web page is also showing how to open the bottom case indicating which screws to be loosened. Be careful length of screws are different, so note which ones fit where. The picture 2nd from the bottom is the one after repair. The connector is marked and you may notice the flexible cable stays flat and does not bow upward.
I did opened my D70 and taped a small roll of a paper towel on the flexible cable as it presses cable down held by a bottom cover.
Hope helps.
Apr 30, 2011 | Cameras
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Chr
try formatting your memory card...
Dec 02, 2008 | Nikon D70s Digital Camera
My nikon d70 gives me a "For" error
If green LED is blinking constantly when camera is turned on, this is a known problem with D70. Upgrade camera firmware from nikonusa.com website.
May 09, 2008 | Nikon D70s Digital Camera
Nikon d70 green led stays on
Nikon D70s Digital Camera Logo
490 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
