Hi, I have a cocoon AV sender (5.8ghz) connected to Foxtel IQ2 via RCA - I can get a clear picture on my receiver TV (Sharp Aquos) but no sound. All cables are connected. Can you help
Shuttle83
  • 1139 Answers
SOURCE: sharp tv audio problem
You may have a tunner problem. Try this turn your TV to channel 3 connect you cable to it and select a channel. If thesound has a problem what may be happening is the the audio detector may not be working properly or the audio amplification stages may not be working correctly from the audio detector. You will have to test the audio stage from the detector to the last audio amplifier to troubleshoot this problem. If you have experiences in this that's good if not take the set to a qualified service technician.
Posted on Sep 18, 2007
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
petraman7
  • 1175 Answers
SOURCE: Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
SF
Posted on Jul 07, 2008
  • 374 Answers
SOURCE: 60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
Posted on Jan 04, 2009
I would like to connect my DVD player and Foxtel to me tcl smart tv but have no idea how it do it. Can somebody please help me.
depends on the output from Foxtel
is it antenna rf coaxial on foxtel ?
is it hdmi output on foxtel box ?
is it an AV RCA cable output on foxtel box ?
what does dvd player use for its output ?
Suggest you google these connection interface types and work out what is the output types
if rca then use av input on tv
is hdmi then use hdmi input on tv
then use select input source on tv to switch to whatever you used.
Jan 20, 2017 | Televison & Video
Hi, I have a Samsung LED Smart TV Series 8. However, I can't for the life of me find an AV out so that I can connect my Cocoon AV sender (uses composite cables) to it. Do you know how I might connect...
Sorry , since your TV does not have any A/V analog output you must buy one of the HDMI converter box from an electronic store...and than do whatever you want..
pls visit the URL below as an example..eBay is the cheapest on the market as well.
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
HDMI to Composite /S-Video Converter HDCP analog AV RCA....US $42.96http://cgi.ebay.com/HDMI-Composite-S-Video-Converter-HDCP-analog-AV-RCA-/120741847360?pt=LH_DefaultDomain_0&hash=item1c1cc66140
Jul 09, 2011 | Televison & Video
How do I connect my Sharp Aquos to my audio system-- TV to preamp and so on?
hi,
you can connect th analog audio output of your tv to ur preamp's any of the analog audio input, if it is a stereo preamp. if u have a AV receiver, then connect the digital audio output ( optical )of your tv , to any one of the digital input of ur AV receiver.
ok
Dec 20, 2010 | Sharp LC-32SB24U 32 in. LCD TV
My sharp aquos 32 in tv has sound but a black picture, what is the problem
Hi
Do you have no picture on all imputs i.e, tv or any AV inputs, can you get any on screen graphics from the menu system?, if not, it is possible the inverters( controlling the voltages to the screen) or a supply to the inverters has failed, either way the TV needs to be repaired. If you do get on screen graphics from the menu it would suggest that you have a external source problem either from you aerial (if you have no picture via the tv input) or a connection/syncing issue with an external source
regards
TechSupp82
Dec 11, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The picture via my Onkyo-sr674 has degraded
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Jul 10, 2017 | Onkyo TX-SR674 Receiver
WIRELESS LINK FOR SKY+ BOX
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
Sound, but no picture
The hdmi inputs on this unit go directly thru the main digital pcb. and the component inputs feed thru the av pcb then to the main pcb. If the composit hook up do not work and hdmi inputs do work the unit has a bad AV pcb.
Nov 08, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
