Question about Whirlpool Kitchen Ranges
Oven will not work. My oven is a whirlpool wall ove
  • 3 more comments
  • Ray DeLotell May 04, 2010
    my oven will not turn on!
    it is a wall oven about 4-5 years old, and has been in place for that length of time!
    I do not know what mdel it it as far as I can tell it is a 4-5year old wall oven by whirlpool!
    How hard could it be? It will not come on (oven only) please give mw some insight! Thank you!
    electric
    yes and yhank you! There had been a thunder storm and an error code came up that read E6 what does this mean
  • 2,100 Answers
The first thing to do is check the breaker. OK, Are you getting any error codes? We just had this happen, One of my clients bought a new house and it was full of cheap appliances, The contractor made it look good, but they have all been replaced within 2 years of being brand new, the oven was repaired. Took out the control panels and replaced them with new, still had to have the guy come out and program the thing. because it still wasn't right. I believe it was a warranty job. Check it out. Hope this helps.
Posted on May 04, 2010
  • Ned  White
    Ned White May 04, 2010
    OK, did you check the breaker? Is the panel lit up? Clock running? Have you had any thunderstorms lately? Power surges. These things are not like the old days of mechanical switches, everything is electronic. And they are sensitive.Is this a double oven? Let me know.
  • Ned  White
    OK, sorry I didn't get back sooner, but I had to go to work? Go figure. The E6 error code, cannot be erased or fixed. It has to be replaced, the key pad, but,,,, you can try this. Go to the breaker box, shut off the power to the range for a minute, and switch it back on. Sometimes that will reset it.
    The parts diagram for your oven lists three control
    panels.
    1. 8300427- black
    2. 8300428- white
    3. 8300516-
      biscuit
    The part number for the electronic oven
    control is 8302319.
    Hope this helps.
  • 787 Answers
Could you please be a little more specific? What doesn't work?
  • 3 more comments
  • Tudor Valean
    Tudor Valean May 04, 2010
    What Whirlpool model is it?
    Have you installed it according to the instructions in the user manual?
  • Tudor Valean
    And what model is it?
  • Tudor Valean
    Is it an electric one or a gas one?
  • Tudor Valean
    I'm asking because I have to rule out some of the possible causes.
  • Tudor Valean
    That means the circuit has been overloaded and damaged. You need to call a technician to have it fixed.
What product do you recommend to clean the ove? Does afresh work
hi debbie.
you have put your question on the washing machine page,but i think you mean oven?
if its the oven then go to this link might help you out.
What product do you recommend to clean the ove Google Search
Nov 07, 2017 | Washing Machines
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Please tell me where the temperature sensor on a ge range is located
Open the oven door and look in the back wall of the oven near the top. Most GE temp sensors are on the right. Some models are on the left.It is metal about 3 inches long and smaller in diameter than a pencil.
To chamge it out,unplug the oven,re,ove the retaining screw and pull it out of the oven. Pull carefully until the wire connector is exposed. Unplug the connector to completely remove the sensor.
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Jun 24, 2009 | Whirlpool RBS305PD Electric Single Oven
New oven, new installation. power at wall outlet, no power at ove
Open wire...either ground or neutral.
Lights are 110volt...and possibly there is a disabling feature due to open wire, as stated above, not allowing oven to operate.
When ground and/or neutral are provided all should work.
Feb 28, 2009 | Ovens
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Can't put door back
This may help:
http://www.whirlpool.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196278.pdf?PIPELINE_SESSION_ID=62e5768ec0a8503448ca0e04446c0ca5
Oct 27, 2007 | Whirlpool RBS245PDS Electric Single Oven
Kitchen Ranges Logo
37 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
