Question about Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Sony kdl-40w3000 does not turn on. Standby light blinks 13 times. What is the problem
Sony kdl-40w3000 does not turn on. Standby light keep blinking. What is the problem
Posted on Aug 23, 2010
3 Suggested Answers
  • 1156 Answers
SOURCE: kdl-40w3000, when power button pushed,
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this will to fix the fault......
Posted on May 29, 2011
welcomejee
  • 10594 Answers
SOURCE: wont turn on
It is back light inverter board failure error. Check back light inverter board in TV.
Posted on Aug 08, 2009
Sony Bravia KDL-52WL130. Turns Off and standby blinks 13 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 18, 2015 | Sony Televison & Video
Kdl-40w3000, when power button pushed, tv comes on for a few seconds then shuts off then standby blinking light comes on 13 blinks, pause,13 blinks pause, etc
May 29, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Our Sony Bravia kdl-40W3000 turns on very briefly and then shuts off, and there are no blinking lights. Does this tell me anything?
Does the LED atleast stay in standby mode after it shuts off or does it go off altogether. It sure sounds like a protection fault causing the relays to power off the set but I would like to get as much info as you can give me to zero in on the source of the problem.
May 29, 2011 | Sony Televison & Video
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
Wont turn on
Aug 08, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Goes on for about 6 seconds and shuts off goes into stand by
Do you see standby light blinks? if yes, please count it and let me know.
Jul 23, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Apr 27, 2009 | Sony BRAVIA KDL-40V3000 Television
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Feb 20, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KDL-40W3000 40 in. LCD HDTV Logo
1,617 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
