Question about Epson DFX-9000 Matrix Printer
Printer repair what is the problem, when DFX 9000 indicates error 03?
    Genius:
  • 1,447 Answers
Carriage load measurement error-chances are you will have to sendit to a servicer to have it fix
Posted on Mar 29, 2008
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
What is the meaning of "ERROR 03 on my dfx 9000
you have to clean the CARRIER ENCODE SENSOR SCALE
which is a <<tape>> under the printhead and detects the movement of the cr assembly
Aug 18, 2014 | Epson DFX-9000 Matrix Printer
Error 13 on epson dfx 9000 printer
Hi Good day!!
Error 13 is a printer error code that signifies that there is a paper jam. You need to check the jam in the entry if your system shows this error. Error 13 also indicates the need to replace the pickup roller in the printer.
Aug 29, 2012 | Epson DFX-9000 Matrix Printer
Error : paper jam Epson DFX-9000
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Sep 14, 2010 | Epson DFX-9000 Dot Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Error13 for epson printer dfx 9000
ALLO CHO MINH HOI MAY IN KIM EPSON DFX 9000 BAO LOI ERROR 03 LA BI PAN GI VAY ?
Mar 18, 2009 | Epson DFX-9000 Matrix Printer
DFX 9000 Printer on display Error 03 plz help out.
DFX 9000 Máy in L?»?i hi?»?n th?»? trên 03
Jan 11, 2009 | Epson DFX-9000 Matrix Printer
Error 07 ,turn off Printer on dfx 9000
Timing fence could be faulty or dusty. Clean it and test if that fails replace it.
Jul 23, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
657 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
