Question about Nortel 2550T 48-Port Ethernet Switch (AL2515E02-E6)
Hi , I have 5 ports at Nortel switch were connected to AP , these 5 ethernet ports was configured as NON POE ports because the AP has external power adapter , Suddenly i found these ports completely stop working no light at all so is there any chance that these poerts burned because i can'ty find any article of how ethernet port burning , I check the configuration for these ports they not shutdown.
2 Suggested Answers
  • 209 Answers
SOURCE: Hi Team We replaced our existing
As you described it there shouldnt be any problems with your configuration, there should be auto ip conf. enabled so VoIP phones should accept 1st IP range automatically. If that doesnt help contact your operators. Thats all. Good luck!
Please rate my solution! :)
Aleksandar Adzic
Posted on Aug 23, 2010
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
How can I activate PoE port on avaya2526T switch?
Try this:
Jun 18, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
I have a HP ProCurve MSM 410 AP. It will accept clients and then in 20 minutes it starts dropping connections..and will not let them back on with a restart. I have poured over the specs for both AP and...
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
- Mike
Mar 28, 2011 | HP ProCurve MSM410 (J9426A) Pre-802.11n...
Switch not connect hyper terminal
If you are connecting to the switch using the console port using a console cable. Make sure your settings for hyper terminal are on COM1 and the baud rate is 9600.
If you are trying to telnet, you will need to assign an IP address to the VLAN in order to telnet into the switch and configure a password or it will not let you in.
Mar 04, 2011 | Nortel 2526T-PWR Ethernet Routing Switch...
Confi stack on nortel switch 2526
Hi friend i want help can you give me the reply. i have 4 nortel 2550T-24 port switch but i don't know how to active stack config.
Sep 27, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
Display does not lights up when connected on ethernet cable, PC is ok thnx
thnx for your attention
i found the solution,
the ethernet cable was able to transmit IP traffic,
but not POE, may be one of the 8 wires was defective
it's ok now with a new cable,
connected on a POE port on the switch
best regars
bernard, from Paris, France
Jan 22, 2010 | Nortel 1120E
Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Mar 20, 2008 | Cisco 7940 IP Phone
Nortel 2550T 48-Port Ethernet Switch (AL2515E02-E6) Logo
43 people viewed this question
Top Nortel Computers & Internet Experts
J John
Gopi Venkatesan
Gopi Venkatesan
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
