Question about Health & Beauty
My quickie aspire wheelchair will not move. The joy stick activation light is continuously flashing and I have no power to move forward or reverse. I have charged the battery, but it is not solving the problem
  • fsbtco May 04, 2010
    It is several years old and has been very dependable. I do not find a model number anywhere. I am away from home and do not have access to the information that came with the chair. From checking the internet to is an F10-F11.
    President:
  • 1,851 Answers
You need a new battery.
Posted on May 04, 2010
  • 787 Answers
Is it new or started having this problem after a while?
Also, what model is it?
I have a quickie electric wheelchair. The right axle was locked up. I turned the power on and now all I get is a flashing light. The batteries are new and fully charged. What could the issue be? The home...
The right motor will need to be replaced. What reason did they give why Meduicare wouldn't pay for repair If the Aspire is your only chair then Medicare will pay. If you have received a new chair since the Aspire then Medicare will only pay for repair to the newer chair. You can contact a repair service other than the home Medical to get the chair fixed. You can contact Roadrunner Mobility @ 1-800-467-2668 for repair Hope this helps you
Jun 26, 2011 | Quickie Wheelchairs Quickie Aspire Power...
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
My chair will not move and the charge light flashes continuously, both when the charger is plugged in and when it is detached.
The VSI controller is manufactured by Penny and Giles Drive Technology. A picture of all the flash codes and their meaning can be found at:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
This is a terrific way to diagnose the problem with your chair. A technician will have a hand held programmer to read all the faults stored in the VSI controller log. This will give you an overall picture of the condition of all the electrical components of the chair, past and current faults. Hope this helps.
Jan 19, 2011 | Quickie Wheelchairs Quickie Aspire Power...
When i plug in the charger the led light stays on green but on the joystick the lights are moving back and forth as if it is charging but wheelchair does not move
Joy When you plug in the charger the lights on the joystick will scroll because of something called charger inhibit which disables the joystick when charging It is a safety feature. Now when you disconnect the charger turn off the chair and then turn it back on you should then get all the battery lights indicating the charge level If fully charged all the lights will be lit. If after you unplug the charger and you still get the scrolling lights then you have a problem with the charger inhibit function in the joystick and it will have to be replaced. Hope this helps you
Sep 25, 2010 | Quickie Wheelchairs Quickie Aspire Power...
The wheelchair will only move when the charger is plugged in. Unplug and all lights are normal but no motor actuation. thank you fo4r your help
berry boy Not alot of information but when you say all lights are normal do you mean the battery level lights are all lit up and there are no flashes. Usually when this happens the battery level is too low to make the chair move. When you have the chair plugged up the charger gives enough power to make it move. If you have a digital voltmeter set it 200 vdc then plug the 2 test leads into the 2 outter charger port holes. You should be able to read the battery level and after a full charge should be reading 25-27 volts. Hope this helps
Sep 19, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Lights on control panel are blinking chair will not move
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jun 26, 2010 | Quickie Wheelchairs Quickie Aspire Power...
I have a quicky power chair, i think its an F-35 b...
I think you have locked your controller, or put it in "sleep mode". Turn on the chair again and push the joystick forward, then to reverse, then forward again and release. It should fire up. Let us know if that worked.
May 21, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
