Question about HP PSC 1315 All-In-One InkJet Printer
I want to refill the color liquid of my printer model 1310-
Should i change the cartridge or i just buy the color liquid from the shop if my printer cannot print because no color liquid left in the cartridge. tell me please
  • 4,041 Answers
Hi there
It is up to you but some times by refilling it will not show ink leavals so it will not print, so it best to change the cartridge.
All the best Pineworks
Posted on May 04, 2010
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Black and color cartridges refilled. originals back in printer...printer says no color cartridge installed.. have cleaned contacts on cartridge and machine, NO difference. can we print just in black if...
You need to have both black and color cartridges installed with functioning electronics to use your printer. Sounds like your original color cartridge and the refilled color cartridge you purchased both have bad electronics. I recommend Cartridge World or Office Depot for cartridge refills because they electrically screen their cartridges before selling them. You need to buy either a new or refilled color cartridge for your printer to work.
Feb 09, 2010 | HP PSC 950 All-In-One InkJet Printer
My color cartridge was low and I refilled it. Now my printer is
The electronics on your cartridge are bad and you need to buy either an HP original or a new refill to fix the problem. I recommend Cartridge World for refills because they test for electrical problems before they refill cartridges. If you do not have one of these stores in your area, Office Depot refills are the next best thing.
Jan 15, 2010 | HP PhotoSmart 1115 InkJet Printer
Esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Jul 26, 2009 | Kodak ESP 5 Printer
Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Apr 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Dell 926 Printer ink refill instructions
I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
How to
I think those cartridges can't be refilled because of the chip they have on them. You can buy compatible ones that can later be refilled. Check in a refill shop.
Jul 22, 2008 | HP Single Yellow Refill Bottle for HP...
Color
I am assuming from your brief problem description that you are getting bad colors when you changed your color cartridge. Are you using a new and certified HP ink cartridge? Are you doing a refill of your old ink cartridge or have bought one of those "re-manufactured" cartridges? The head in the cartridge is very sensitive - when they are damaged or poorly handled - it could result in cross contamination of the color inks. Hence - the brownish color you see could be the result of that cross-contam. My impression is that the remanufactured or older or continously refilled cartridges may be more prone to getting damaged - maybe bec of inherent wear out. Hope this helps.
Nov 30, 2006 | HP DeskJet 3325 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
