Question about Bosch Axxis WTL 5400 Dryer
Will not start and without light on buttoms, light inside Ok  How to fin fuse and disassemble control panel
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryerwill not start - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 06, 2010
Back light, dome light, front panel, radio, air not working
Try looking for a fuse box in the glove box. Even try opening both front doors and looking on the sides of the dash. O e other spit may be under the steering column. You will have to lay on the driver side floor looking up to find d it if its there
Jan 11, 2014 | 2002 Dodge Grand Caravan
My Bose radio stopped working, no sound no lights AWRCC1
Hello
Check its power cord first. If it is OK, check its power supply section inside. There will be a fuse at the power supply rectifer board. Check it. If it is found opened [damaged] never put an other fuse, without proper check to the power supply and main audio amplifier section. There must be some reason for the blow up of this fuse. Without rectifying the fault, replacing an other fuse, may make more components to get damaged, and the repair work may cost more. OK.
Feb 26, 2012 | Bose Wave radio/CD remote control -...
Nothing happen what should i do now? i try to unlock and is nothing on the screen is black and by the screen with tha clock say F2;E1
If your oven is displaying the F2 E1 error code, then the problem is probably NOT just that the CONTROL LOCK feature on the oven was engaged.
The F2 E1 error is probably an indication of an electrical fault inside the electronic control system for the oven.
Sometimes this is simply a temporary error in the control panel circuitry which can be cleared by shutting off the electrical power supply to the oven for a minute or so at the breaker box.
Other times this is caused by a loose wire or faulty connection inside the control panel, or it is simply a faulty control panel circuit board.
Try switching off the electrical power to the oven using the corresponding breaker at the main fuse panel in your home. When you switch the power back on after a minute or so, press the CANCEL button on the oven controls panel.
If the above procedures do not work then you will likely need to contact a local service technician to disassemble the oven, diagnose the cause, and repair the problem.
If your oven is new, be sure to contact your dealer at the place of purchase since the cost of the repair may be covered under the terms of your warranty.
Good luck.
Joe.
Nov 03, 2011 | KitchenAid Ovens
GE Profile WPRB8050D0WW Top Down Washing Machine from 2/2002 Unit refusing to start, shows 43 minutes. I "assumed" this was an e43 error "excessive drive system brake time", but cannot...
Only have a few minutes before running off to work this morning....but try this
If that does not work, then comment back and I will look for more info tonight...
heatman101
Sep 26, 2011 | GE WPRB8050D Top Load Washer
My start button not showing
Hi ,
This could be a problem with the operating system , I want to stay with you on this fix ,
1st , can you hit the start buttom on your keyboard , its got a windows logo on the buttom
2nd- if you can click on control panel and go into system restore , pick a date it was working and click on it ............please let me know if this helps , I really want to help you Roy
Aug 01, 2011 | Computers & Internet
One of my microwave light under the microwave are blowing off with a big flash. The microwave still working after that, but the other light still on when I press the button to turning off. I decide to...
If your model is NN-P295SF, then the service manual is here.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line.
Sometimes you get lucky and only a fuse blows, but either can cause a failure on the controller.
We often see this problem on the control panel, which we regularly repair by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jun 29, 2011 | Panasonic NN-P295SF Microwave Oven
No power
Depending on the brand and full model number, it may.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download many brands' mini-manuals here.
Sometimes the problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with aone year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Jul 09, 2010 | Hotpoint RVM1535MMSA Microwave Oven
My over the range microwave oven light(underneath) does not work. The bulbs were tested, they are OK. Is there a fuse to replace?
Maybe. In some Whirlpool models there are several fuses.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I doubt that it's a fuse, though. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 09, 2010 | Whirlpool Microwave Ovens
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
Fedders window model A6Y12F2B "New Unit",,only 10 days in use! Just stopped working No Power To Master Panel Air Conditioner Not Working Fuse Panel/Breaker ok,Outlet ok,,power to plug...
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Jun 22, 2008 | Fedders Heating & Cooling
Dryers Logo
153 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
