Question about Acer Aspire One PC Notebook
My Acer Aspire One went into hibernate mode by itself and am unable to turn it back on unless I remove the battery and use it solely on electricity mode. Please help.
  • 32 Answers
Keep press power button for 1 mins and your laptop will turn off. when you turn on your laptop. disable hibernate mode.
to return to your desktop from hibernate mode press power button quickly. windows will resume
Posted on May 05, 2010
My acer aspire one pav70 went into hibernating mode . how do i get it out of hibernation
It could have gone into hybernation for more than one reason.
Either it has been programmed to or the battery is low. Either way pressing the power button momentarily will get it out, if the power supply is plugged in or the battery is charged.
To remove the hybernation option, right hand mouse click on the battery icone on the desktop and change you power settings.
Hope that helps.
Nov 28, 2010 | Acer Aspire One Netbook
Hibernation mode
First thing to try is to remove the battery and disconnect the AC adapter. Press the power button for a full 10 seconds to drain residual power from the capacitors on the board. Give it 5 mins then put the AC adapter and battery back in and give it a try. You might also refine your hibernation settings - I had a 5000 which is similar and finally turned hibernation off. Also check for a pin switch that the lid pushes down when it closes to see if something is holding the switch down when the lid is raised. I dont remember if that model has a mechanical push switch or a magnetic. Magnetic shouldnt do it but mechanicals are very prone to getting stuck.
Jul 02, 2010 | Acer Aspire 3000 Notebook
My Acer went into hibernation in the middle of
You can try this ... you probalby already have ...
Unplug the external power. Remove the battery. Come back tomorrow. Put the battery in. Reconnect the external power. Come back the next day. Give it a try.
If you are still under warranty, Acer has a pretty good Chat Support program. Give them a try.
Thanks for your interest in FixYa.com
Feb 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
I was trying to install a webroot spyware application to my acer aspire 3000. once it asked for product code and i typed it in, my pc went into hibernation and I cant get it to turn back on. please advise....
Hibernation usually happens when the battery goes flat. It may have nothing to do with the software. Please ensure the laptop is well connected and the battery is charging. And then try to turn it on again. If I'm wrong and the application you purchased is actually a malware in disguise, then I'd suggest you try to boot with a recovery CD and then uninstall the application. Unless there is physical disc damage that the malware caused it should be able to turn on. Hope it all goes well. If my ideas help you, please do rate me. Thanks
Feb 05, 2010 | Acer Aspire 3000 Notebook
Netbook went into hibernation, how do i get it out?
take out the battery then put it back in, plug laptop in and start it up.
Jan 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Acer One Aspire is stuck in hibernate. After it updated itself and said it was preparing to shut down, it was stuck in the preparing for shut down mode for hours. When I let the battery run down to turn...
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Nov 11, 2009 | Acer Aspire One PC Notebook
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
All of a sudden" going into hibernation"
try to open ur laptop cover .
on the mainboard there is usually a jumper located near the cmos battery. try to change its position for 3 seconds and return it back to its normal position.
this way u will clear the board memory .
start ur computer and load default settings.
hope this will help.
May 14, 2008 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
435 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
