Question about Sony KP-57WV700 57" Rear Projection HDTV
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
I ordered your Sony KP-57WV700 Convergence Repair Kit from tvrepairkits.com and attempted the repair. I replaced the convergence chips and turned the TV back on. It seemed fixed. My picture was back to normal.
But after about 5 minutes my TV powered down. It would only stay on a few minutes before powering down.
I did some research and read that this may be due to a bad soldering job. So I desoldered the convergence chips and resoldered them. Now my TV's convergence is worse than when I began the repair...and the TV still will not stay on for more than a few seconds.
I'm not sure what to do at this point. I did not change the pico fuses as I did not know how to test them with the meter I have. Any assistance anyone can provide would be greatly appreciated.
  • financesmart May 04, 2010
    Thanks for the quick reply Chu. Looks like I need to get new chips for this set.
    One other question, do you have any idea why the TV would not stay on the first time? The convergence was perfect but the TV just powered down. Do you think this was bad soldering, blown fuses?
    I just don't want to spend more money and run into the same problem again. Thanks!
  • Sony Master
  • 8,457 Answers
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
Posted on May 04, 2010
Testimonial: "Very quick reply and helpful!"
  • Chi Chu May 04, 2010
    U skip a pico fuse or a resistor right?That why it shutdown.These convergence kit been tested and been replaced many times before by the people that put it together.So replaced all the items,what ever in the kit.
    U have soldering flux,not buy some because it will help,the solders flows will be better and stick to the componnents ur solering more evenly and smoothly.
I set converger and watch tv but after changing the channel a few times I need to set converger again and again do you no why??
Posted on Aug 22, 2010
2 Suggested Answers
tlm931
  • 273 Answers
SOURCE: Only HD channels have 3D look - Sony KP-57HW40
have you ran magicfocus on hd channels and if you have and still have problem
it will most likely have to have adjsutments done in the service menu when running on a hd signal
Posted on Oct 24, 2009
Green will not align with others
The convergence has failed on your TV and will need to be repaired. You can call a shop or do it your self with a convergence repair kit from sites such as www.TvRepairKits.com . This is a failry common problem that all projection TV sets will have at some point.
Jul 26, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Want to perform manual convergence. when i get to the convergence section, buttons on tv will not perform the task. remote has not worked since quite new according to previous owner. Is there a reason for...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 28, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Guns won't stay aligned. Looks like a bad 3D movie
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board,must require to change 2 STK convergence ICS and some or all it resistors to solved the convergence problems.U have soldering tools and matrials and know basic's solderings work?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair it ur self.The shop will cost $300-350 for parts and labors.
Jul 10, 2010 | Sony KP-57HW40 57" Rear Projection...
IHAVE A COVERGENCE PROBLEM WITH SONY KP-65WS510 THE RED AND BLUE ARE OUT OF SYNC.
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Sony KP-65WS510 65" Rear Projection...
Convergence sony kp-57ws510
Convergence are daed.Have tools,lilke soldering iron,solders,solder wicks? Must know how to solders?Must repalaced 2 STK convergence ICS,some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 31, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
The colors are out of alignment on my sony kp-61hs10 how do I fix it?
Ur convergence is dead.Must know how to solders?Must replace 2 STK convergence ICS,and some or all it resistors.Tries these websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 18, 2010 | Sony KP-61HS10 61" Rear Projection...
My tv is a 57ws500 and the picture is shadowed by red color and can't seem to get the red out. what do i need in order to have picture in excellent working order?
Ur convergence is dead.Must know how to solders?Must replaced 2 STK convergence and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Sony KP-57WS500 57" Rear Projection...
Unable to perform convergence.
Ur 2 STK convergence ICS,and some or all it resistors are dead.U must know how to solders?Replaced the 2 STK convergence ICS and some or all it resistors,will auto focus ur convergence back to normal buy itself.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Mar 10, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57WV700 57" Rear Projection HDTV Logo
581 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
