Question about Brother MFC-215C All-In-One InkJet Printer
Black ink cartridge is full but will not print leaves only a shadow -
Mix-it-up
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
Mix-it-up
  • 832 Answers
SOURCE: Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
Posted on Feb 24, 2008
SOURCE: black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Posted on Dec 20, 2008
  • 116 Answers
SOURCE: Black ink not printing
replace print head assembly
Posted on Aug 02, 2009
komguy
  • 2306 Answers
SOURCE: black ink will not print. Colours ok
Neither solution will help, Brother has had some bad printheads and the only repair is to install a new printhead. It's a shop repair and runs around $170.00. Under warranty there's no charge. The thing you really don't want to do is blow air into the system as it takes another full ink to get the air bubbles out. Sorry for the Stupid help above.
Posted on Feb 09, 2010
My printer is not printing black ink, although both black cartridge ink levels are are 3/4 full. I have reset to factory settings and cleaned the print heads.
Leave the print head ( not the whole cartridge!) soaking overnight in a little puddle of solvent e.g. print head cleaner or alcohol. This is much more effective than the printer clean program or a quick rub with a cotton bud.
Oct 15, 2013 | Canon MP560 All-In-One InkJet Printer
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
My printer ink is full and it just printing in black and yellow
The ink leaves the ink-cartridge, and should flow through the ink-jets to be sprayed onto the paper.
If some of the ink-jets are clogged (blue, red) and some of the ink-jets are fine (black, yellow),
then you need to run a few "print-head-cleaning" cycles, to try to unclog those ink-jets.
Jul 19, 2011 | Office Equipment & Supplies
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
All of a sudden my Canon MP830 is printing only very light, unclear very light black lines on the chapter of my dissertation I am trying to print. All the ink tanks are full & I've done 2 deep...
Doesn't matter if the ink tanks are full. They may also have dry ink on headers. You could try to draw a black rectangle in MS Paintor any other software and try to print it at the best quality. You also could try to remove the black cartridge and see if it leave a ink stain on a absorbant paper (like a napkin). If does not leave a ink stain it means that the ink is dry.
If this is the case you may try to boil some water. When the water is boiled take it away from the fire and sink the cartridge into the boiled water and keep it there until the water cool down.
Aug 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Not printing black
Hi
1. Make sure that you have removed the plastic cover from the cartridge nozzle .
2. check if your black ink cartridge is full - put the nuzzle on the tip of you finger if it leaves ink drop then it is full and should print ok , if it didn't leave ink on your finger then it is dry and you should buy new cartridge .
hope it helps
Jul 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
Brother MFC-215C All-In-One InkJet Printer Logo
48 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
