Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have recently had need to reconnect my wireless router but it is not working i am not sure if i have connected it properly can you help
    President:
  • 524 Answers
  1. Click on START,
  2. Right Click on MY COMPUTER
  3. Select PROPERTIES
  4. Click on th HARDWAREi have recently had need to reconnect my wireless - 2_bing.gif Tab
  5. Click on the DEVICE MANAGER Button
  6. Scroll down to NETWORK ADAPTERS and find your wireless card.
  7. Right click on it and select PROPERTIES
  8. In the DEVICE STATUS what is written in there <REPLY 1>. If it says THIS DEVICE IS WORRKING CORRECTLY - - Then drivers2_bing.gif are ok here. If it says something else POst Back with what it says. and then Update the drivers.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
Internet connection worked through my wireless router until recently on my Satellite L305-S5877. I have turned off my firewall to no avail. I have limited connection to the router wirelessly, but no...
First unplug all devices from your router. There should be a small button (mine is depressed with the point of a pen) on your router that is used to reset the router. I have to reset mine from time to time. Hold the button down for two minutes or so to allow it time to reset. If that does not work then disconnect your modem for a few minutes to allow it to reset Then reconnect everything in the exact reverse order that you disconnected. I needed to contact my router manufacturer the first time for help in resetting it.
Feb 15, 2011 | Toshiba Satellite L305-S5877 Notebook
It says that my wireless is connected, but I cannot get onto the internet
I found that drivers of the wireless card may not work with the latest drivers of the router. As was in my case. I updated my router. All good. Updated my wireless drivers on laptop, I see network but can not access it (Dell says they are still working on it). However, I could connect to other wireless connections. So it was the Dell card for sure.
Did you recently update any drivers? Maybe try rolling back. If not, maybe try updating them and the router.
Sep 22, 2010 | Computers & Internet
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Windows Vista Ultimate: Internet connectivity
Make sure your IPv4 settings property is set to AutoObtain the IP address under the Network properties for the wireless card
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Have wireless connection, but can't get online
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Jan 25, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless internet connection
be sure to turn on the wireless switch on your laptop. press Fn and F8 to turn on wifi. try to reconnect to the network. if it doesn't work, uninstall/reinstall the device driver for your toshiba laptop. if you know how to reconfigure the router, you need to change the SSID and change the passphrase. (if this is a secured network) if you don't know how to reconfigure the router, please contact your router manufacturer.
i hope this helps.
Sep 10, 2008 | Toshiba Satellite M45-S265 Notebook
Help
check if you are getting a valid ip address (e.g. 192.168.1.x for linksys routers, not unless you changed the router's ip to something else) from your router. if so, try to disable any anti-virus software and firewall installed on your computer. if not, make sure that you are really connected to the wireless signal of the router. one common error message that'll let you know that you are not properly connected to the signal is "limited or no connectivity". if you're getting that message, try to disconnect and reconnect to your wireless signal and make sure that you are using the correct wireless security (network key) if you have enabled that on your router. it's also advisable to customized the wireless settings of your router to prevent interference from other wireless networks.
hope this'll help.
May 30, 2008 | Linksys Wireless-G WRT54G Router
Cannot sustain network or internet connection
It is quite possible that your issue is due to the DHCP function of your router. I would check the DHCP settings and the lease time that is set. Its quite possible that the lease time is running out and its having difficulty renewing a new IP.
Apr 24, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
