Question about Hotpoint Aquarius WF000 Front Load Washer
WF430 On ON Off Flashing and mini load
Same problem for me.One of the baffles in the drum broke as uysual and some coins and a sock got into the first hose where the white ball is. I tool that off and cleaned it out. I reconnected the whole lot. Checked the outlet hose which is clear. My only thoughts is the pump its self may be blocked but seems ok. Still wont work.Should I buy a new one?
  • 67 Answers
What is the actual fault
Posted on Apr 04, 2008
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
How do I remove coins in the drum?
I just tried all manner of bending, pushing and prying the drum baffle. Can't get it to move. I'm thinking I need to break it to clean behind it then install a new drum baffle. At $49.35 plus tax and shipping I'll leave the coins there for now.
Sep 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
Sounds like coins between the basket and drum. How do I remove the coins?
If it has baffles for washing, check to see if you can lightly press the baffle to one side (press firm but don't snap it out) while rotating the drum by hand. I do this with my Whirlpool Duet and the coins eventually just slide out and into the drum where I can see them.
Dec 06, 2010 | Maytag MAH8700A Front Load Washer
I know that I am asking this for the third time; however, on the other two I forgot to notate the make and model. Again, after I opened the top of the dryer, there were no coins, it seems to be the screws...
If the screws holding the baffles just came out of the baffles or if the baffle broke they can be reinstalled. If the screws have ripped though the drum, the drum will need to be replaced. The screw part number is 33002973. The short baffle part number is 33001755. The tall baffle part number is 33002032. If you need the complete drum it is part number 33001889. Below are the instructions on how to replace the drum. Parts can be ordered from this link.
below is a link to the service manual for the info u need to take aprt or replace the dryer drum on a Maytag Neptune, I suggest u print it and then enlarge it if u can read it.
http://media.fotki.com/1_p,swdbrqkqdgssrtkxgtqsskgwtqkq,vi/stkwfgbrgxkgtddqfqs/1/1303472/5961857/image7951020310251998097img-or.gif
Apr 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Wont drain and cant find filter
diconnect from mains ... remove back porthole panel ... look in you will see a black sump hose connected to bottom of drum by a band release the band and you will see the filter most likely with a sock in place blocking the whole sump
Jun 02, 2009 | Hotpoint WF430 Front Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Apr 24, 2009 | Electrolux AWF1235 Front Load Washer
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore elite drum baffle dryer
remove the top panel and each fin has 2 5/16 screws holding them to the drum. turn the drum so the fin is on top and remove the screws then remove the coins
Oct 18, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Hotpoint Aquarius WF000 Front Load Washer Logo
163 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
