Question about AEG Lavamat W1050 Front Load Washer
Hi, My Lavamat w1050 barrely switches itself on, and when it does so rarely, it barely holds on for a few seconds, before getting shut off completely. I suspect the front panel control board holding all the push buttons may be faulty. Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
If the heater is down to earth it wont start. try disconnecting the element and see if it starts if it does replace the element,
Posted on Jul 16, 2010
Pressure switch
These screws should NOT be adjusted. :)
Sep 29, 2013 | AEG Lavamat W1050 Front Load Washer
MY aEG OKO-LAVAMAT 610 WASHES BUT DOES NOT EVACUATE.
Check the drain filter, see if the hose is not clogged (blow it), verify proper operation of the pump and the pressure switch if necessary
May 30, 2011 | AEG Lavamat W1050 Front Load Washer
Detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
END LED blinks 3 times
Worked out the problem - the heating element was burnt out. Very easy to replace.
Nov 13, 2008 | AEG Lavamat W1050 Front Load Washer
End led blinks 3 times
Had this exact problem (fills, empties and then light blinks three times) and found that the heating element was burnt out. Very easy to replace.
Nov 06, 2008 | AEG Lavamat W1050 Front Load Washer
Water not pumping out and therefore no spinning occurs
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Aug 14, 2008 | AEG Lavamat W1050 Front Load Washer
Still not working
Press & hold 'end of cycle' for 5 or more seconds. Disconnect from mains for some time, or over night. Then re-start afresh the program.
Jun 02, 2008 | AEG Lavamat W1050 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
regards,
Alf
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat W1050 Front Load Washer Logo
133 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
