Question about Nyko AIR FLO Gamepad (743840806103) Game Pad
NYKO AIR FLO PC JOYSTICK ITEM 80610 DRIVERS
I WAS GIVEN A NYKO AIR FLO JOYSTICK BUT IT HAD NO DRIVERS FOR IT COULD YOU HELP ME FIND THEM
  • 1 more comment
  • Anonymous Apr 27, 2008
    I was given an Airflo for my game but no drivers and i searched everywhere for one but can not find one plz help me
  • shane283 Apr 27, 2008
    Air Flo™ PC with no drivers please help me P.S. NOT EX! i have searched for 1 hr to find the drivers please help me! thank you for your time..............
  • Anonymous Oct 17, 2008
    I have a similar solution, but it is a problem with windows XP. The gamepad seems to work in normal circumstances and in past games, but I now suspect that I need specific drivers for a game I am trying to play because some of the buttons are recognized only sometimes and resist being mapped, etc.
    New Friend:
Hi.
Air flo PC Joystick item 80610 drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Posted on Nov 17, 2014
If using vista, I found going to START>CONTROL PANEL>HARDWARE&SOUND>DEVICE_MANAGER>
under "Human Interface Devices" Select the USB device with the error icon on it(has small yellow triangle in bottom right side), right click, select 'Disable'(icon will change) right click again and select 'Enable'
This worked for me, I cannot guarantee it will for you.
Posted on Jun 11, 2008
No drivers needed. In "control panel" go to "Add Hardware". Click "next" until you have the option to "Install the hardware that I manually select from a list (Advanced)", click next. Select "Sound, video and game controllers" and click next. Then select "Generic" in the manufacturer box. One model should show up called "Unsupported Standard Game Port"; select it and click next. And your done. Happy playing.
Posted on May 22, 2008
I was given a nyko airflo pc controller and i need drivers and software to run it. please help?
Posted on Nov 28, 2008
Http://www.fixya.com/PostAnswer.aspx?thid=468892&prdid=10259&ctgid=0
Posted on Nov 08, 2008
    New Friend:
Hi
you can check check on this link http://www.fixya.com/support/t468892-nyko_air_flo_pc_joystick_item_80610 i hope it will work NYKO AIR FLO PC JOYSTICK ITEM 80610 DRIVERS
Posted on Nov 30, 2015
SOURCE:
HOW TO USE ON GAMES
The Nyko Air Controller is meant for PC Games, so if you're using it on the 360 or the PS3 you might run into some problems. I've used this controller myself so I can speak from experience. What you want to do is download the calibration software from Nyko's website:
http://www.nyko.com/customer-support/
If you're using this to play an Emulator you will need to set up the Joystick Calibration in the settings. (Almost any game for that matter you are going to need to use the in-game settings to calibrate the joystick.)
Hope this helps.
Jan 26, 2011 | Nyko Airflow EX PC Game Controller...
NYKO Airflo EX new driver
What you need is not really driver based.................You will have to turn on the analog button (You can find it on the game pad usually in the middle.
Note also that not all games will really support the joystick unless you configure it to do so in the game settings.
All the best.
Jul 26, 2010 | Nyko AIR FLO Gamepad (743840806103) Game...
Set up for Nyko air flow pc.
all games and most games for that matter do support game pad and so does the pc. Though with some pad you will need its drivers to get it working.
On the other hand games that i call "click and follow" such as rise of nations can never be played with a game pad and also the game must support game pad. For pacman i found out it supports 4 way joystick which means you should not have any problem playing with the game pad since it has the 4 way navigation buttons.
good luck with your game
Jul 04, 2010 | Nyko AIR FLO Gamepad (743840806103) Game...
Why can't I load my NYKO software on my pc/Vista
http://rapidshare.com/files/362751095/Nyko_Airflo_Drivers_2.0.0_For_Mac_and_WinXP.zip
Here are the most up to date drivers. If still problems, install in compatibility mode. These do work on vista 32 bit as I have used them before
May 08, 2010 | Nyko Airflow EX PC Game Controller...
I can't get my air flo game controller to work with my hp mini
please install the drivers and then try.It would work fine then
Mar 05, 2010 | Nyko AIR FLO Gamepad (743840806103) Game...
Nyko Airflo EX Help
Drivers for Mac and Windows XP and Vista!
Authentic and safe.
Jul 21, 2009 | Nyko Airflow EX PC Game Controller...
Nyko airflo pc not driver fail to install. vista 64bit laptop
Here you go, drivers from my disk I found. For vista you may need to run in compatibility, but ive had no problems before.
Jan 27, 2009 | Nyko Airflow 80610 Game Pad
Driver
This controller is completely plug and play for windows xp operating system. The NEW HARDWARE wizard can detect it over the internet and install the driver automatically in windows xp. You can download the drivers for windows 98 that will make it operate however I'm unsure what the link is although i recommend the usual, google it ; )
Sep 04, 2007 | Nyko Airflow 80610 Game Pad
Nyko AIR FLO Gamepad (743840806103) Game Pad Logo
15,785 people viewed this question
Top Nyko Video Game Consoles & Games Experts
Ekse
Steve Mason
Level 1 Expert
Bill Boyd
Are you a Nyko Video Game Console and Game Expert? Answer questions, earn points and help others
