Question about Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F
After defrosting the freezer would not restart, it seems to be trying to "kick in" but will not start the familiar humming sound that is makes when its happy
  • 523 Answers
Over load and relay
Posted on May 05, 2010
Testimonial: "Good response, short in words and bids another question"
My freezer turns on when plugged in and cools to below zero, then shut off and warm to 37 degrees before turning back on. I just replaced the temperature control thermostat and the defrost thermostat.
Sounds like compressor is overheating and taking hours to restart. check by listening for the hum of the compressor shortly after it has reached temperature. also check the condenser is clean and fan working.
Dec 07, 2015 | Kenmore Freezers
My side by side refrigerator on the freezer side is dripping water at the bottom on to the coil. The coil seems to be making a sizzling sound and turning red is this ok
There is a defrost heater that periodically turn on to melt the accumulated frost on the coil. The heater will warm the coil to about 45 degrees and a defrost thermostat should shut off power to the heater. The defrost cycle should only last about 30-45 minutes then the compressor should kick on. If you find that some items in your freezer are melting, or that the freezer is not maintaining temperature, then something is wrong. Hope this helps you.
May 24, 2011 | Maytag Freezers
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
May 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 | Freezers
Fridge Freezer in Autodefrost mode
Power surge can cause problems such as you have. I am not familiar with your brand but it sounds like the defrost timing circuit is your problem. Defrosting the surface of the back wall is not the answer. The cooling coil in the freezer is behind the back wall normally and a surface defrost does not do the trick of defrosting the coil. Have an appliance service tech check it out for you.
May 30, 2008 | Freezers
Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail hvac.tech@gmail.com
May 18, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
Mar 16, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F Logo
248 people viewed this question
Top Zanussi Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
ray gallant
Todd Arndt
Todd Arndt
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
