Question about Car Audio & Video
I have vauxhall astra with radio/cd playeri have had battery disconnected and now after putting code in wrong several times, my fault. it just comes up 7 safe and i cant shift it or put my code in any ideas? cheers Jeff
  • 32 Answers
You will have to contact the main dealer and get them to reset the system
Posted on May 04, 2010
Vauxhall astra radio code lost
On radio or car manual; there must be attached label which shows radio serial number. You must contact to opel & provide that radio serial number in order to get acivation code for your car radio. As far as i know; there is no way to work original radio without having activation code.
Nov 19, 2014 | Car Audio & Video
What do Fault codes P0068 mean?
P0068 means that the Throttle Position Sensor doesn't agree with the Manifold Absolute Pressure Sensor; the readings it gets from the two sensors don't make sense with each other. If someone has replaced one of those two sensors, they may have put the wrong one in. Otherwise, one of those two sensors is bad... in which case your car should have given you a second error code telling which of those sensors it thinks is bad.
Jul 26, 2014 | Vauxhall Astra Cars & Trucks
Astra coded radio cant enter code??
I would suggest that your radio got a voltage surge when your battery was recently removed and re-connected. I would either:
1) Remove radio (if you have the special tool), unplug and re-connect harness, or
2) Pull the fuse in the fuse box for the radio (may be two), or
3) Disconnect the negative post to the battery, wait 30 seconds and re-apply (very quickly).
If the display does not reappear, I'm afraid the radio is damaged. Let me know.
Dec 18, 2013 | Car Audio & Video
Vauxhall astra cd30 infotainment system display does not come on when key is put in ignition. Cd and radio work fine. Any ideas please ?
Hello! In the under-hood fuse box check fuse # 36 (7.5A)...I hate guessing...And I'm guessing on the Year of your Astra as a 2008...If I'm wrong let me know...But that fuse powers up the Driver Information Center...Send a comment...guru...saailer
Jan 18, 2012 | Car Audio & Video
I have a vauxhall astra with a cdr 500 cd player in it but it will not play any cds or radio and keeps sayin error TR_ _ _ CD
From what I have been told, you would need to reset the unit. With a reset, basically disconnecting the battery cable you would need a four digit code. It was one that came with the car or the radio. It will put it into safe mode as if the radio was stolen. Once it is in safe mode you would then need to punch in the 4 digit code. That will reset the unit and allow the radio to begin working. If you do not have the 4 digit code you would then need to take it to a dealer and have them reset the code. I was told it would only be about $25 at almost any dealer.
Oct 28, 2009 | Car Audio & Video
Vauxhall astra s reg
One of two things has happened
Because your battery went flat and you then created a short circuit the radio may be locked out and need a start code which should be in your manual
Worse case is that by applying a reverse polarity to the radio you have blown the protection diodes up inside it, if so it is a back to the maker job
Aug 19, 2009 | 1996 BMW 318
Radio code for vauxhall corsa
The units anti-theft program was activated when the battery was disconnected. If you don't know the 4 digit code, try to contact the previous owner or most higher end car audio dealer/installers will offer a service to reset the anti-theft code program, for a fee.
Aduz
Mar 25, 2009 | Car Audio & Video
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
Entering Code for Car Stereo
Turn on the ignition, turn the radio off fully. (by preeing the volume wheel knob) press AS or the button that turns it to CD mode (should have circle on button)keep it pressed and turn radio on. wait for a beep then it should be somthing like:
10----------- (10 being the number of tries left)
use buttons 1,2,3 & 4 to input your code. press the button more than once for it to rise higher.
Hope this helped.
BTW i got the same problem with my dads astra. but i dont even know the code :(
Nov 24, 2007 | Car Audio & Video
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
