Vulcan oil heater
I recently bought a house that has an old oil heater on the wall. I have no idea on how to start it any ideas?
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Posted on May 05, 2008
  • homeygnomey Jul 27, 2011
    This is great thanks. We are trying to ressurect an old Vulcan oil heater but its tank is empty. We are in Lithgow NSW. Does anyone know where we might buy some oil from or does anyone have some left in a tank somewhere that we can test this old girl with. scarlett
Turn valve on at bottom of oil tank,turn air control(Center Knob) to midway position, oil control to number 3(outer knob) pull lever under this knob out,and fan control to either hi or low, once heater strarts oil control can be turned up to increase heat, but air control will also need to be adjusted, you should end up with a blue flame and the ceramics glowing red.
Posted on Mar 28, 2008
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
Hi We recently bought a house that has an 40 series Vulcan oil heater in it. Can anyone tell me how to light it. It has a knob on top with numbers from 1 - 5 (2 being ignite). A lever on the bottom that...
Make sure the tank outside has oil ( Kerosene) in it. Check the fuel tap (under the tank) is turned on. When you press and hold the heat control button, it should ignite after a few minutes. The lever on the bottom is the fan control switch (high speed or low speed fan) Make sure that the unit is plugged into the power. If I remember correctly, a red light appears to say it is powered up on the bottom left hand side.
Jun 19, 2014 | Heating & Cooling
Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Jun 22, 2010 | Heating & Cooling
Vulcan C-X Gas Furnace Model 902
If you bought the house, did your hire a house inspector to check everything out? You can go back to him and have him double check his evaluation. I even got my inspector to pay for half of a repair when something broke right away after we moved in. If you are renting the place, ask the landlord to send a furnace repairman to do an annual inspection and cleaning on it. Just a few ideas for you to consider for peace of mind.
May 16, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Any idea where I can get an instruction leaflet for operating a Vulcan Continental boiler. Thanks Leigh
you will have to find a supplier that sell them, they don't have a web site but call to your local plumbing supply house and see if they might know who sells the item, that would be your starting point,, good luck
Jun 24, 2009 | Water Heaters
Vulcan Oil Heater not operating correctly
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
Jun 16, 2009 | Heating & Cooling
Vulcan gas wall furnace keeps turning off, and has err f1 on the control panel. Any suggestions? It is Sunday afternoon and about 8 degrees!
No idea what the problem is but - We have a manual vulcan gas wall furnace about 3yrs old and it has always been switching off since installed which is a real bummer on cold days. We had it checked out whilst under warranty but the technician did not fix the problem. Im not sure if it has anything to do with the gas supply but seems more of a product fault. Lucky weve got a combustion stove as well!
Jul 27, 2008 | Heating & Cooling
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
6,026 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
