Question about One Step Ahead New Holland Tractor Set
My daughter jumped our Chevy 6L truck with our New Holland TC 30. Now, tractor will not start. Battery is good and lights work just nothing when you turn the key. What has she blown?
  • larrykrauss May 04, 2010
    Thanks. I'm in the UK and my wife is at the house in Texas. Any idea where the fuse box is on that model? I'll try to talk her through it.
    Genius:
  • 1,016 Answers
It sounds like she has shorted out the main starter fuse, so just go through the fuse and look for the starter fuse or ignition fuse's.
Let me know if you need more information.
Jason
Posted on May 04, 2010
  • Jason Maurirere
    Jason Maurirere May 04, 2010
    Yep get her to have a look under the bonnet by the battery and also inside the cabin on the right hand side. either the dash or by the accellarator.
My New Holland TC-30 tractor runs fine but when we start it, the fuel & water gauges slowly go up and finally peg, staying pegged until we shut it off.
First thing ALWAYS is to check the grounds. It's a bad ground connection on the gauges at the sending units.
Oct 28, 2014 | Cars & Trucks
I am looking for a service manual for a new holland tc-30 compact tractor
Try this site
http://www.ssbtractor.com/tractor_manual_search.cgi?tractor_manual_make=New+Holland&tractor_manual_model=TC30
Dec 10, 2013 | Garden
TL80 New Holland tractor will not start
Check connections at battery, starter solenoid and starter motor, make sure they are clean and tight. Check the both ends of ALL wires. Check starter is not jammed. Check starter mounting bolts are tight. Make sure battery is good by using jump leads from known good battery (like your car).
Nov 17, 2013 | Garden
My daughter has a 2000 stratus... she drove it the other day and it was fine. She went to start it tonight and the interior lights came on but the car would start. we tried to jump It but it still did...
You should know how old the battery is
They can last 3 years or 9 years
You could have it tested at parts store
If over 5 years old just replace with the
largest cca rating for that size or group battery
A good battery is about $120.00
Check the cables for corrosion & being
tight.
Jumping a dead battery can be a dangerous
proposition if any cells are shorted inside
Nov 15, 2012 | 2000 Dodge Stratus
New holland TC33DA won't start
Sounds like a bad starter. Try giving it a few good taps while turning the key. Sometimes they can get warped and get stuck. Had to start my car for weeks doing this till I could afford a new one. Could also be the solenoid too but im not sure if it would even click if that was bad. Good luck.
Oct 19, 2012 | One Step Ahead New Holland Tractor Set
No power at all
This might sound stupid but check to make sure the terminals are attached tight so they are making a good connection. This happened once on my truck because the ground cable came loose somehow
Sep 25, 2012 | 1999 Mazda Millenia
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
One Step Ahead New Holland Tractor Set Logo
120 people viewed this question
Top One Step Ahead Toys Experts
Andrew Taylor
Andrew Taylor
Are you an One Step Ahead Toy Expert? Answer questions, earn points and help others
