Question about Toshiba Qosmio G25-AV513 Notebook
Q f45 av410
Shut down wont let back in; fix it can't find anything wrong; all other options froze. only access; administrative password for reset
This problem virus problem plz u creat a new user throw the control pannel u can creat user accounts after that u will enter the new user and appear full window u can try shut down
manoj kumar india 00919358120529
plz reply me me soon
Posted on Mar 26, 2008
Reset password
In order to reset the password for the NComputing Administrative Console, you will need to re-install the software and reset the password through the installer. To do this, complete the following:
Launch your NComputing software installer:
  1. The installer will request a password, type anything.
  2. The installer will inform you that the password is wrong, select OK.
  3. You will then be asked if you forgot your password, select Yes.
  4. You will be prompted to restart your installer, select OK.
  5. Your password is now reset; you may Cancel the installation and access your administrative console.
Oct 21, 2014 | NComputing L230 Computer Access Terminal...
Password removal
remove the CMOS battery for a few days then put it back and try that.
Jul 04, 2014 | Toshiba Qosmio F45-AV410 Notebook
My computer starts in safe mood ask for systems password i donot have and will not do anything else
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instructions exactly.
Dec 07, 2012 | Dell Computers & Internet
Lost logon username and password and account was as an administrator. did not make recovery disks and cannot access files anything. Need to reset pc
you can fix this problem by going to http://www.wikihow.com/Hack-Windows-With...
read wat it says (i know it says hack, but its not bad or anything, it is just used to change the password)
i know this works too, so don't be scared of viruses or anything
good luck :)
Jul 06, 2010 | Compaq Presario CQ60-220US PC Laptop
When i turn the power on after two minutes it shuts down right away. tried to charge it still the same it will turn on for 2 mins then shut down again. i tried rebooting it press f8 but it gave me another...
you got 2 things here:
1. pc shutting down unexpectedly
2. blue screen
1. the cause could vary:
a. cpu overheating: make sure you are letting the laptop to breath, open/clean vents.
b. motherboard failure: get a new laptop.
c. battery failure: try to take the battery out and connect the laptop and test/replace the battery as needed.
2. blue screen: if it is a Blue Screen of Dead, try to note any error codes and post back or at this stage it could be virus: take the hd out, connect it to an enclusure and hook it up to another good computer and attempt to save the usuful data. then reinstalled hard drive in laptop and reinstall os.
b. hadware failure: replace laptop.
on the password:
the only three possibilities where you may be asked for a password is if you're trying to access a password protected bios (which you rarely do with f8) or if you're accessing the recovery console in which you need to enter your windows user name and password or if you're accessing the computer in safemode in which you can enter any user name and their password or the user name: Administrator and for password it could be either blank or whatever password was set when windows was installed
good luck!
Mar 19, 2010 | Toshiba Qosmio F45-AV412 Notebook
ADMINISTRATOR PASSWORD -HELP!!!!!
The administrator password in Windows XP is the password used to access the "Administrator" account.
This account usually doesn't show up on the logon screen and most people don't know it exists. Usually that's okay because you won't need to use your computer under this account very often.
There are a few times when you will need this password! When you're accessing the Windows XP Recovery Console or you're trying to boot into Windows XP Safe Mode, you'll need this password before you can continue.
Follow the steps below to quickly find the administrator password on your computer!
Difficulty: Average Time Required: Retrieving the Administrator password may take a few minutes up to hours depending on the situation Here's How:
  1. Try leaving the password blank. More often than not, the Administrator password doesn't exist at all! Just press Enter without typing anything when asked for it.
  2. Enter the password to your account. Often times, depending on how Windows XP was setup on your computer, the primary user account will also be the administrator user account.
  3. Try to remember your administrator password. If you installed Windows XP on your computer yourself, you probably set the administrator password during the Windows XP installation process. If that's true, you might be able to make really good guesses at what the password might be.
  4. Have another user enter his or her password. If there are other users that have accounts on your Windows XP computer, one of them may be setup with administrator access.
  5. Recover the administrator password using a password recovery tool. Password recovery tools are software programs that work by making super-fast guess after super-fast guess until the password is discovered.
    Note: Some password recovery tools is the list I linked to above also have the ability to transform regular user passwords into administrator passwords. This could be valuable if you know your account's password but it's not an administrator account.
  6. Perform a clean installation of Windows XP. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
    If you're just curious about your administrator password, I wouldn't suggest this extreme solution. However, if you're needing the administrator password to access diagnostic tools and this is your last effort to save your PC, performing a clean install will work. Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Jul 03, 2009 | Sony VAIO VGN-UX280P Notebook
Finding Sata drivers
Ok, let me see if I've got this right, you want to replace vista? but you need the SATA drivers? To do a dual boot, you usually need to install XP first, and Vista second. As for the SATA drivers, if the XP cd boots up and allows you to edit the partitions, then the SATA driver is already integrated. And here is the download page for your laptop:
Qosmio® F45-AV410
Mar 26, 2009 | Toshiba Qosmio F45-AV410 Notebook
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Mar 23, 2009 | Toshiba Qosmio F45-AV410 Notebook
Blank screen on Qosmio f45 after power down when a program froze
try taking out the operating system then putting it back in and rebooting it.
Dec 31, 2008 | Sony Toshiba Qosmio F45-AV411 Notebook
Forgot Administrative password
I got the following from the windows help and support:
OPTION 1
Using a password reset disk is the best solution.
  1. If you have typed the wrong password, you'll get a message that says your user name or password is incorrect. When this message appears, click OK.
  2. Click Reset password, and then follow the instructions.
OPTION 2
If there is another administrator account on the computer, that administrator can change the password for the account you can't remember the password for. If you do this, however, you will lose access to any encrypted files, encrypted e‑mail messages, and passwords stored on this account. If you don't have encrypted files or stored passwords, then this option will work for you
OPTION 3
If you don't have a password reset disk or another administrator account, you won't be able to reset the password. If there are no other user accounts on the computer, you won't be able to log on to Windows. In this case, you will need to re-install Windows.
Jun 24, 2008 | HP Compaq Presario SR2150NX PC Desktop
Toshiba Qosmio G25-AV513 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
