Question about Macally iBall Trackball
My pendrive is showing write protected and I am not able to create new folders
  • 143 Answers
Try formatting it in any new and fresh system which is not afected by any antivirus
Posted on May 04, 2010
WRITE PROTECTED
  1. Open Registry editor of your PC
For this you should type command "regedit" on run.
2. Navigate to the following key:Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
3. Double-click on the WriteProtect value in the right-hand pane of Regedit.exe. Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer.
Nov 10, 2013 | eMachines D3315 PC Desktop
Tip
How to Make Invisible Password Protected Folder Submitted by Srikanth on...
How to Make Invisible Password Protected Folder2761870.jpg Submitted by Srikanth on Thursday, 10 December 200930 Comments Do you want to password protect your folder? Do you want to make it invisible so that it remains unnoticed by the normal users? Well here is a way to do that. In this post I will show you how to make a password protected folder in Windows without using any additional software. Here is is step by step procedure to create a password protected folder.
How to create a Password Protected Folder
Step-1: Create a new folder (Right-click -> New -> Folder) and give it any name of your choice. For instance I name it as ABC.
Step-2: Now in this folder place all the important files, documents or any folders that you want to password protect.
Step-3: Now Right-click on this folder (ABC) and select the option Send To -> Compressed (zipped) Folder.
Step-4: Now a new compressed zipped folder gets created next this folder (ABC) with the same name.
Step-5: Double-click on this compressed zipped folder and you should see your original folder (ABC) here.
Step-6: Now goto the File menu and select the option Add a password.
ie: File -> Add a password
Now a small window will pop up and here you can set your desired password. Once the password is set, the folder will ask for the password every time it is opened. Thus you have now created the password protected folder.
How to make it Invisible
Step-1: Now Right-click on this password protected folder and select Properties.
Step-2: At the bottom select the option Hidden and press OK. Now your folder gets invisible (hidden).
Step-3: In order to unhide this folder go to My Computer – >Tools -> Folder options. Switch to View tab, scroll down and under Hidden files and folders you’ll see the following two options
  • Do not show hidden files and folders
  • Show hidden files and folders
Now select the second option and press OK. Now the invisible folder becomes visible in it’s location. To access it you need the password. To make it invisible again repeat step -1 through step-3 and select the first option and click OK. Now the folder becomes invisible once again.
I hope you like this post. Pass your comments!! Cheers
on Mar 30, 2010 | Computers & Internet
I have a kingston 4gb pendrive, currently i have a problem with new folder in it. i never put any new folder in it and there it appears to have 'new folder' thr. when i try to open it, it wont open, and...
best thing to is plug your pendrive into ur computer
now make a new folder onto ur desktop
right click on desktop-options -new folder
now right click in new folder -scroll down to rename -and type a name u can remember
now open your pendrive
pick all your folders you want to keep
hilte all except (new folder)now right click and pick desktop then the folder you named now give it a name at the bottom now press ok
once done
take out pendrive
now check your files are in the folder you renamed
now plug pendrive in right click -options format
once formatted your pen drive is empty and ready to use again
hope this help
Aug 30, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with Pendrive Virus which can not delete by formatting !
You should down load a trial version of NOD32 you have to supply them with your e-mail address.they will send you code to put on after installing that would be valid for 30 days but trust me. You'll scann ur Pc and ur ext Drives. the virus will be away.
Jul 24, 2009 | Electronics - Others
Pendrive problem 32 gb it is protected can't work properly
Rushabh,
--- Your PenDrive is virus infected, please use any good antivirus to scan your PenDrive as well system and go ahead.
your pendrive is being shared by some virus so that they wont let ir be formatted, to solve it pl do following
1. start task manager, and see currently running processes
2. Insert PenDrive and try to locate the new tasks got activated, try to end those tasks.
3. see the files/folders in Pendrive, right click the drive and unhide all of its contents
5. Select all undesirable folders & exe files (like recycler etc)
6. Delete all of them at once and pull the drive out without disabling it
7. Restart your system, and see if the problem is solved.
Alternatively call me 9899780221
Thanks
Zulfikar Ali
Jan 27, 2009 | Ahead Software Nero 6.6 (600901) for PC
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
Problem regarding the write protection of pendrive
sir,
i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format, a window pops up saying that ur pendrive is write protected
Sep 03, 2007 | Computers & Internet
Macally iBall Trackball Logo
69 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
