Question about Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS
TO TAKE DETAILS, METAL DETECTORS(KITS OR PCB). Thank u very much to the attention for me. I visit your web site & I found some details about your Circuits. I need to build a metal detector which can find metal (Gold coins) at a depth of 0.5m (0.2m< depth <0.5m) in rock (stone). It?s good, if the m/c detects only GOLD & Simple indicating system is enough(LED bulbs or uv meter). Please give me the full details soon. Thank U
  • 60 Answers
SOURCE: i need a manual for bounty hunter quick draw 2 metal dector
You can download the full users manual at http://www.detecting.com/products/
here is the link to your quick draw II detector:
http://www.detecting.com/pdffiles/qdiiman.pdf
If you want to purchase a hard copy of the manual look on eBay under Bounty Hunter Manual cost is around $6.
Posted on Oct 20, 2009
  • 60 Answers
SOURCE: i need a manual for my bounty hunter metal detector
You can download the full users manual at http://www.kellycodetectors.com/pdf/manuals/pioneer505.pdf
  • 509 Answers
SOURCE: where can I get an instruction manual for the
Here is a pdf website...
http://www.detecting.com/pdffiles/ManualTRACKER4.pdf
Posted on Feb 19, 2010
SOURCE: Precision Gold Metal Detector With Digital Display Set Up
instruction manual for the precision gold metal detector: go to www.maplin .co.uk. then type in L24BK into the product search. the metal detector will come up.then go to bottom of page where it states "media" if you click here a pdf of the instruction manual will come up for download.
Paul
Posted on Apr 17, 2011
SOURCE: cmb118920@yahohow do u set the
yes, please let me know how to find gold only with my radio shack 63-3006
Posted on Apr 25, 2011
Why is my samsung hln617w tv all inputs give no signal
main pcb approx $72.00 at
http://www.shopjimmy.com/samsung-bp94-00434a-main-analog-board.htm
however thay are out of stock. Be sure this part # is a match to your complete model# B4 trying to order, this site lists the various models this pt# fits.ALSO considering the age, they may not be able to get anymore of these.I recommend calling to confirm.
As for firmware updates, that info can be found at Samsung web site:
http://www.samsung.com/us/support/contact
under product support. you might also check at the Samsung web site for the Main PCB. expect it to be much higher & please have your complete Model & Serial numbers available when you contact anyone.
Apr 29, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Tip
Our pump was running however was not removing the water. Had tried everything....
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  7. Locate the electrical connection to the pump and disconnect.
  8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
  9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
  10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
  11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
  12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
  13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
  16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Feb 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Cps ls790b not working
1.CHECK THE PROVE ANTENNA CONTACS IF ARE WELL CRIMPED. ALSO CABLES RED AN BLACK SOLDER POINT IN PCB,
2CHECK TE SENSOR TIP.
Apr 16, 2013 | Cps Products LS790B Multi Freon Leak...
Can you buy one metal detector that does all different types of detecting?
In most cases, one metal detector will do it all except for specialized situations. So nugget detectors and underwater ones wont be good for more geneal detecting.
Feb 21, 2013 | Retail Supplies
I am very curious about metal detectors; how they work etc. Can anyone explain it to me in simple terms but with a diagram?
Take a look at the Indepth Info Site - they have a fairly basic explanation but with a diagram that might help. But you're right - metal detectors are fascinating!
http://www.indepthinfo.com/gadgets/metal-detector.shtml
Door won't open
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Details about this fault has been described here.
May 15, 2012 | Televison & Video
Red standby light is on.... when you attempt to turn TV on the red light goes green for a few seconds and then clicks back to red. If it is the voltage processor IC, is it labeled on the PCB where I can...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 04, 2011 | Broksonic CCVG-3276 32 in. LCD TV
Paul
Jul 30, 2009 | Bounty Hunter Digger Metal Detector
Bug detector help
I'm thinking of buying one. Did yours work? Were you able to get any support for using it?
May 29, 2008 | GPS
Bounty Hunter Land Star Digital Metal Detector with Ground Trac Re-Tune - LSTAR w/FREE UPS Logo
147 people viewed this question
Top Bounty Hunter Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bounty Hunter Optic Expert? Answer questions, earn points and help others
