Question about Samsung LN32A330 32 in. LCD TV
I have the converter box i have a plasma samsoung do i nstill need a antenna
  • Samsung Master
  • 8,457 Answers
Yes,u need a good antena,like a digital antena or a roof antena to recieve good free air DTV signal.U don't need a converter box,because ur tv is a digital tv.
Posted on May 04, 2010
My sylvania plasma does not have a coax its the #68421PEM how do I get over the air tv channels
You are going to need a digital converter box for antenna reception and that box is going to have to come with S-video or composite V and A rca style jacks. Look on amazon or ebay.
Feb 09, 2017 | Sylvania Televison & Video
I have a 42panasonic plasma tv model#th-42pwd7 it has no cable antenna terminal in the back of the tv but it has rgb terminals i have a converter box and x box360 how can i get a antenna tv signal
Its a Progressive Wide Plasma Display. It wont have a built in Turner. So you will not be able to connect antenna to the TV.You have to use a set top box or cable box and connect its output t the TV.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Televison & Video
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
I have a panasonic 42inch plasma, problem is it only pics up 2 stations i even have a converter box ive tried to set and re-set but nothing works what can i do?
You may need to use a larger or different type of antenna. The website listed below will suggest the proper style and size antenna for your location.
Click Here to begin
Then click CHOOSE ANTENNA.
May 17, 2011 | Televison & Video
How do I connect my digital tv converter box to this plasma tv. My antenna in and signal out are both co-axial cable. Which input do I use on the back of the tv? Would I use a BNC adapter to coaxial...
Here is a cheap and easy way to connect this for you....
Get a VCR (often times can be found at goodwill or garage sales for very cheap) and connect the coax cable from the output of the Converter box to the Antenna/Cable in on the VCR then connect from the RCA output from the VCR to the TV. Tune the VCR to Channel 3 most likely and change channels through the converter box.....
Good Luck and please rate this solution....
Jan 05, 2010 | JVC GD-V500PZU 50 in. Plasma Television
My antenna has a coax-my 50 in Maxent mx50X3 has no coax hook up. How do I connect these two?
That unit does not have a tuner so it does not have an antenna input. You need to connect a cable box, satellite box, VCR with a digital tuner (or an additional DTV box for converted input), or DVR to one of the HDMI, S-Video, or Component inputs to view TV.
Oct 26, 2009 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
Jan 10, 2009 | Insignia Digital-to-Analog Converter for...
NEC plasma sync 42mp2 vm2g
If your referring ot an outside antenna or cable, your set does not have a tuner, it is a monitor style. You will have to get a converter box and use the video input ( yellow) (red/wht-audio) on the tv, or the component input ( green, blue, red ) on the tv, provided, the box has the output for it. Most cable boxes have these and the antenna dtv converter boxes do not as far as I know but look into it.
Dec 27, 2008 | NEC PlasmaSync 42MP2 42 in. Television
TV antenna
Hi splhcb,
Your television is already an HDTV, meaning it is set up for receiving digital broadcasts. In this case, you should not need a separate converter box for over-the-air reception. You will need an antenna, but the type you purchase depends on things like how far you live from broadcast towers, landscapes, buildings, and where it will be located in your home. Although many antennas are being marketed as HDTV compatible, if you already own an antenna you likely can continue using it. Otherwise, it is best to speak with someone at the store who can weigh the factors in your situation to recommend the best antenna.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 28, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Samsung LN32A330 32 in. LCD TV Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
