Question about Microsoft MS Windows XP Professional SP2
Disk drtive problem
While using my computer a box appears saying ''there is no disk in drive D'' and they also give me three options -cancel,try again, and continue. what should i do to fix it?
  • Dave King
    Dave King May 11, 2010
    Usually you see this if you closed a program with a cd or dvd in the drive. Then the next time it keeps looking for it and creates the error. Its not as much an error as it is annoying. To stop it just hit cancel or insert the disk in the drive again.
    Problem Solver:
  • 19 Answers
Clean the eye of your disk drive or try removing it and reinstalling it.
Posted on May 04, 2010
My hp laptop says no bootable device found. Was told it was the hard drive so I replaced it. The new hard drive says the same thing. What else could be wrong with it?
Try accessing the BIOs of the computer. The following are the three keys most likely to have the Hp computer go into the startup bios.
Look to see if you hard drive is listed and is the boot device.
  • Turn off computer.
    • Start computer continuously hit the F1 key
    • Start computer continuously hit F2 key
    • Start computer continuously hit esc
If the Hard drive is not listed then if you have the original disks for you computer try booting up with them. There may be other problems keeping the computer from finding the boot sector on your hard drive. The bios will give you some place to look. Do not use the option save you changes.
Dec 03, 2015 | HP Computers & Internet
My laptop says that one of my disks need to be checked for consistency and then stops on 2 of 3 checks with 62% checked. then reads an unexpected error has occured on one of the disks and freezes. I also...
This is not an easy issue to solve using this method (posting text or email) but I will give it a try!
There are many things that can cause the problem you described. Your memory cards could be loose inside the pc. You can try removing & reseating them to see if this solves the problem. Your partician could be damaged. Your hard drive may need replacement. If your pc came with recovery software, you might try turning on the pc & putting the system recovery disk inside the drive & then restart the pc and try booting from that drive to start the recovery process. If your pc came with recovery software installed on a second drive located in your computer, then you need to follow the instructions on how to access system recovery which are listed in your manual and also flash briefly on the screen when the pc is loading windows (you should see something like press F2 to enter recovery briefly on the left side of the pc when it is first starting up. It only displays this command briefly. Try restarting a few times if you do not see it) . Once in recovery, follow the prompts to start the process to see if the pc can recover and start windows normally.
If you choose cancel disk check, and the screen your describing in your post is a blinking cursor where you can enter commands - try typing "help" and press enter to see if it will give you a list of choices to execute. If it is a command prompt and gives you this list, try scrolling with your arrow keys to find disk check or check disk. Windows has options to repair bad areas of particians, but I am unsure if they would go any farther then the test that is currently running and unable to get passed 62%.
If you have an operating system disk (Windows Xp, Win 7, Win Vista - full versions - not upgrade software) that matches what you are running on your computer you can try restoring or replacing the opearting system to see if that solves your problem. Try putting the disk inside the pc and restart to get it to boot from the disk drive. Then replace your operating system with a new version (warning - this will erase all files that were on the pc) to see if that solves the issue. you can also try installing recovery and/or repair files from the operating system disk. Just put the disk in and restart the pc and read the options that come up - then follow the prompts to repair the system.
If you have questions please use the reply or comment link next to your question on Fixya and I will try and continue troubleshooting until this issue is resolved.
Sep 12, 2011 | Computers & Internet
When i use my hard drive in my computer its works alrght but when i tried to use in a different computer just doesn work it seens to be working but i can see the icon on desktop
i have the same problem
the buffalo harddisk was working fine with my computer but my computer had an error and no way it could open so i bought a new computer and the harddisk doesnt work on it it appears to be empty like when i plug it a box appears for open folder i open it and its empty then i tried opening it in three other computers it gives me the same thing any solution?
May 15, 2011 | Buffalo Technology Buffalo DriveStation...
I have recently upgraded my Mac from OS 10.4 to 10.6.7. Since then I am no longer able to save my daily back up on MYOB Accounting (Version 16.12). The 'save as' box appears with the details of...
Sometimes when systems are updated disk permissions can get out of sync which can cause problems. What I would do is go to the utilities in the applications folder, open disk utility and click on your hard drive in the left hand box and then click on verify disk permissions button and once run, then if anything has come up click on repair disk permissions. Hope this helps.
May 06, 2011 | Myob Computers & Internet
I have windows xp professional and when I run my
If you get the error-message when you try to boot your computer, your disk-drive is either:
1. not connected to the motherboard
2. improperly connected to the motherboard
3. dead/dying, so that the Operating System files on the disk-drive *CANNOT* be read.
So, the computer tries to boot from an "alternative" device (either the 3.5-inch device or the CD-ROM device) -- if you don't have any media inserted into either device, you will get the error-message.
Oct 25, 2009 | Microsoft Windows XP Professional SP2 Full...
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
When A USB thumbdrive is plugged in, it is reconized but then it doesn't show a drive letter in "my computert" in order to transfer to or from the drive. The safe eject tab is present and does give a drive...
You should plug in the thumb drive, wait for it to recognize it, and then right-click on My Computer. Select the Manage option. Inside the Computer Management window, go down to Disk Management on the right side. The left pane will show you all of your local drives (hard drives, CDRW, USB, Flash, etc...). If you see your thumb drive listed in the drives, you can right click on it and select "Change drive letter and path". This will allow you to pick the drive letter you want as long as it doesn't interfer with any other existing drive letter.
May 13, 2009 | Toshiba Satellite Pro 4600 Notebook
Having problems with installation
Follow the steps to resolve the issue.
  1. On the Windows task bar, click the Windows icon (c01319360.gif ), click Search , and then click For Files or Folders .
  2. Type cmd in the search box at the top of the dialog box.
  3. Press the Ctrl , Shift , and Enter keys to open the command prompt in Administrator mode.
    NOTE: If UAC (User Access Control) is enabled, a message appears asking for permission. Click Continue .
  4. Copy and paste, or type, the following command at the command prompt: C:\Windows\System32\fsutil resource setautoreset true C:\ C represents the drive letter of the local hard disk drive on which Vista is installed. If the drive on which Vista is installed on your computer uses a different letter, replace C with that letter.
  5. Press Enter . Try installing the software again
If the issue still persists, download and install the Windows Installer 4.5 from Microsoft Website by visiting the below web link
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4
Go to the instructions section and download the installer based upon your operating system. It should resolve the issue.
Apr 21, 2009 | HP Photosmart C4150 All-In-One InkJet...
A virus
re format the flash drive
Jan 25, 2009 | Microsoft Computers & Internet
Microsoft MS Windows XP Professional SP2 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
