Question about Karcher 2500 PSI Pressure Washer
Pressure washer karcher
Have connected the water and turned on power. Do not have instruction manual. Power only came for a split second and now won't switch on!
  • Geevan1 Dec 25, 2008
    Hey,
    I just purchased a new HD 16-C Karcher pressure washer, I switch it on & it works for about 5 seconds, then it stops. The on/off switch keeps on turning for itself to the off position (due to the vibration, I guess). The switch doesn't stay at the on section because it is kind of loose. I am hoping I could figure this out by tomorow so I could have some fun on boxing day. If I don't figure it out I w'll check the dealer. Anyone knows what to do?
    Genius:
  • 1,019 Answers
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Posted on Mar 26, 2008
SOURCE:
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
John- power stopped -rest the GFCI STILL POWER WON'T COME ON-KARCHER K2.26M NEW -USED ABOUT 15 MINUTES WHEN THIS HAPPENED
these small power washers are tricky. Keep working with it. It may just be waiting for u to squeeze the trigger to activate. Make sure you have the water connected and turned on.
Apr 27, 2009 | Karcher K2.26 Electric Power Washer
Water coming out of washer
Depending on the model of the machine, it is most likley a cracked control head or split outlet elbow. Remove the covers and run the machine to locate the source of the leak. Ifit is the control head it will spray water from the top just behind the chemical inlet elbow.
Feb 06, 2009 | Karcher K2.26 Electric Power Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher 2500 PSI Pressure Washer Logo
715 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
