Question about Lexmark X4270 All-In-One InkJet Printer
Paper feed pulls unevenly, paper crumples in
Paper feed pulls unevenly, paper crumples in feeder, opening does not reveal a paper jam. There might be something stucfk on pathl
  • 4,041 Answers
Hello there
It worth a try doing this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
    In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
    -David.
    Oct 30, 2010 | Toshiba 2860 Copier
    Paper not feeding correctly
    sounds like there is a piece of ripped paper in the printer
    Jun 18, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
    Paper get jammed in the automatic feeder on top of my printer
    3 possibilities.
    1 If you use this macine to copy labels, there may well be a small piece of a label stuck in the paper path on the crumpled side. Or a small bit of paper.
    2, the paper pickup on the crumpled side is 'polished', and no longer feeding the paper at the same time as the uncrumpled side. They can be cleaned with rubbing alcohol. Though that is a temporary fix and the paper pickups should be replaced if cleaning fixes the issue.
    3 The fuser film has a tear in it on the crumpled side you need to rule out 1 & 2 before going to three again replaceable but a bit more difficult
    May 20, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    Canon mx300 printer feeder pulls unevenly causing paper jam
    the left side of the printer pulls the paper causing the printer to jam when trying to print
    Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
    Paper jam
    If it is getting crumpled in the tray, there is something blocking the paper path.
    What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
    When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
    You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
    Mar 31, 2008 | Sharp AL 1631 Copier
    Document Feeder Jam
    Paper is often guided via mylar /plastic strips within coopiers. It is possible that a certain section has been bent and is obstructing the paper path.
    It is not too difficult to open the document feeder - just be careful in remembering what came from where :)
    The obstruction could also be a piece of paper that was torn while removing a prior paper jam.
    Jan 07, 2008 | Panasonic DP-150A Copier
    Document feeder works for printing but not for scanning
    Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
    Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    Paper Mis-Feeding
    Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
    Mar 25, 2007 | Canon i850 InkJet Photo Printer
    Lexmark X4270 All-In-One InkJet Printer Logo
    116 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
