Question about Samsung HLM5065W 50" Rear Projection HDTV-Ready Television
Tv turns off after 45min to an hr
Hello there, My tv turns off by itself after viewing for about an hr. It starts to scramble flashing white lights across the screen. then turns off. i have to unplug it for a few mins...then turn it back on. after doing this it shuts off again. This time within mins. I've replaced the bulb,hoping it would solve problem ,but to no avail. Please HELP. Best Regards
  • 377 Answers
Hi dear
it may be a power supply issue; if a tube (standard definition) then get of ck’d out but if it’s an HD of any kind it may be the resolution setting due to the fact that DVD players are essentially sending a standard def signal 480p while the monitor is looking for a High Def signal 720p or 1080i or 1080p are the three main settings; as metioned previously disconnect the sources (player decks)?and see if the monitor turns in then un the settings you can check the resolution
It is the protection circuit cutting in and shutting off the set. This is because it detected a short or near-short circuit somewhere within the 8 or 10 sections of the set. Most common is high voltage, deflection amplifiers and main power supply.
You must know how to troubleshoot the circuit and systems in order to repair these kinds of set. You can get lucky, sometimes, by just probing around looking for something that does not look right.
If you are an electronics technician with some good skills I can give you better advice, but if not, you are better off seeking professionial help.
If you want more assistance, I must know the model number and the age of the set. Then I can give you some further ideas.
Also, Allan Wainwright, one of the best allexperts, is good at guiding you on these kinds of things.
Finally, if the set is over 3 or 4 years of age it is not a good candidate for repairs. Why? because it will just fail again, and again, and soon you will have spent so much time and aggravation you will have wished to have cut the losses and just replace it. Sorry, but that is the nature of tv sets once they start to fail.
Posted on Mar 26, 2008
  • Irwan Darmawan
    Irwan Darmawan Mar 26, 2008
    hi dear
    try this
    t's in the service mode.
    With tv off...on the remote...
    push Mute, 1, 8, 2, Power
    set comes on with SM menu screen 1
    using arrows...arrow down to Option and press enter.
    up comes screen 2
    lamp hours and reset are there.
    Be careful! Left and right arrows change things!
    Press Menu to go back a screen.
    Power off and back on quickly to exit the SM and watch.
    plz vote me
    Brigadier General:
  • 6,966 Answers
Initially and sorry but I have to ask, you of course have verified that the Sleep Timer is OFF?
Additionally, it would seem that the unit's problem is either heat related or a cold solder/loose connection. I would discount the possibility of a defective component since if it so then the unit would not even power up in the first place.
Pls post back if you are considering of doing the diagnosis and possible repairs yourself. Should you venture a DIY, pls be reminded of safety precautions when working with electrical devices. Of course this would also require a bit of familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Access to a service manual or at least a schematic diagram with voltage measurements would make the diagnosis a lot easier. If you are not comfortable going this route, then perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Turns off by itselt, now won't turn on
did you see the standby light? in this case you said 5 to 45min. before the unit turn back on, this needs to check the oscillation circuit or the starting capacitor in the Hot area...
Nov 28, 2008 | GE 25GT270 TV
Television wont turn on and has flashing white light
Reset the TV. Unplug it, wait 1minute and replug it. Did it work?
Sep 11, 2008 | Televison & Video
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Samsung HLM5065W 50" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
