Question about Toshiba MK4034GSX 40 GB SATA Hard Drive
For some reason it keeps disappearing from the hardware list when I open My Computer. It won't read any disk in this state. This has happened 4 times now and I can't seem to find a better driver for it. In the past, I have simply uninstalled it and restarted, and it's been recognized and restored to it's place, but this time it won't show up even though it shows in the hardware list in the device manager.
  • Toshiba Master
  • 1,606 Answers
This can be either the controller having a problem or the drive. If you can put the drive in a differant computer and it behaves that would let you know if the problem is the motherboard or the drive.
If it is the drive the next time you get it working back up everything you want. The drive controller is intermittant so it may stop working pernanently. If it is the drive then you really don't want to trust it as a main drive or store anything that you don't want to lose. This is a small drive and you can get a much larger replacement for under $100. If you don't want to spend money you may find one for next to nothing or free just by asking around ie firends doing upgrades or computer shops.
If it is the motherboard then all you can do is switch to the other drive controller and boot using that one (if your bios allows this) or replace the motherboard.
Posted on May 04, 2010
  • 143 Answers
Install the drivers by removing it once, it might also be problem from the operating system end.
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Tip
Providing Care to your computer
<p><span>If you are using computer there are many reasons why you should take care of your <span>computer,</span> and you would probably like to keep running as long as possible. </span><br /> <p><span>Hardware & Software and other are several things you do to have a longer life of your PC. There is always a good thing to clean your <span>computer</span>. A clean hardware <span>will</span> run faster and last longer. </span><br /> <p><span>Here are some options for cleaning and maintenance of the<b> </b></span><span>operating system on your Computer. </span><br /> <p><span>1. Disk Defragmenter run at least once a month. Select this by using this Windows path (Start &gt;all Program&gt;Accessories&gt;System Tools&gt;Disk Defragmenter). The defragmenter will help ensure your Disk files are in the proper place on the <span>computer</span> and will improve the overall speed of your browser. </span><br /> <p><span>2. Clean up old files. Disk Cleanup will help you to remove unnecessary files from temporary folder and system folder which are remain after install/uninstall software frequently. Select this by using this Windows path (Start &gt;all Program&gt;Accessories&gt;System Tools &gt;Disk Cleanup). </span><br /> <p><span>3. Scan for viruses. Viruses are also may cause your <span>computer</span> to slowdown and not work in proper way. You should always install a good antivirus and keep it update.</span><br /> <p><span>Here are some ways you can easily keep your hardware.</span><br /> <p><span>1. Each time a while, you should open it and clean it out. Computers are notorious for accumulating dust. For cleaning dust you can use a vacuum cleaner or a can of dust remover can be done.</span><br /> <p><span>2. Keep your PC cool. You should always make sure that your <span>computer will</span> keep in a ventilated area. This will help prevent life of your hardware to be extended. </span><br /> <p><span>3. Always purchase high-quality hardware.</span><br /> <p><span>By following some <span>tips</span> you can be sure you <span>computer</span> to reduce future.</span><br />
on Dec 24, 2010 | Computers & Internet
Turn on an Asus eeepc1000 netbook with windows xp and the following is what came on the screen " Windows could not start because of a computer disk hardware configution problem. Could not read from...
this could be caused by a number of problems
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 28, 2011 | ASUS Eee PC 900, 900A, 901, and 1000...
Hello, for some reason my Hitachi HTS542525K9SA00 DVD drive is not working. It will open and close but does not show up in the computer section. It shows that it is working porperly in device manager and...
roberts_mich
If you drive is not showing up in My Computer but is showing in Device Manager you may need to reasign a drive letter to the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If you if does not fix the problem they you could have a Windows/driver problem or a hardware problem. I would try to connect the drive to another port on your computer and/or try the drive in another computer. If it works then you may have a motherboard or Windows problem.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 20, 2010 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
My External Hard Drive isn't working anymore, to say the just of it. It's on, lights on(not flashing, it flashes when it's being written to or accessed), usually has a regular clicking noise from it...
When a hard drive makes a clicking noise, this indicates the hard drive has failed and if the BIOS and the Computer Management does not detect it, then this confirm a hard disk failure.
To get the computer operating again, replace the hard disk, then install Windows on the hard disk using the Windows installation CD and the Windows product installation code that is on the label on the computer then install the device drivers and your programs.
Oct 21, 2010 | Samsung Computers & Internet
My mouse on my laptop just takes off and disappears from the screen at times i can get it back but then for no reason it disappears again this is very annoying it may run ok for maybe an hour then it just...
It might be due to corrupt Mouse drivers:
1. Open device manager.
2. Expand Mice and other pointing devices.
3. Right click on the listed Mouse device.
4. Right click on it and choose uninstall.
Restart the computer.
Upon restart the computer will find the missing drivers for Mouse and re-installs them accordingly.
Thanks'
Nnags.
Mar 07, 2010 | Computers & Internet
I am having the exact same problem listed above. I will copy it in case you can't read it for some reason: Drive is mounted on the desktop (Mac OS 10.4). There are no problems with it according to Disk...
for one the drive will not be mounted to the desk top , since it has no operating system installed on it , it will fall redundant to the C drive
in my computer , disappearing is the hard drive booting to the C drive
are you able to use this drive ? if you are I suggest emptying it and
reformatting the drive then fill it back again if the drive doesn't work
check all power cords , cables ect. give me more details to better help you wit this problem David terminalcon
Jan 11, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Unknown device.
First what you need to do is go to the coby website and download the driver for your player and then follow these instrustion to force install the driver:
1. Look for the icon named "Computer" or "My Computer" and right click on it and select properties, this will open a window named "System Properties".
2. In the system properties windows click on the tab named "Hardware", and Select "Device Manager".
3. On this window you will see all the devices installed on your computer, look for the device not working properly (printer, dvd rom, keyboard, camera, mp3 player, etc), if there is a bigger problem, more likely you will see a cross by it, or an alert stating there is an issue with it.
4. Right click on the device you where having problems with and select uninstall, it will give you a confirmation, press OK
5. Once the device disappeared from the list, click on the menu bar icon that looks like a computer with a magnifying glass this will cause for the system to scan for any devices not registered and will force the re installation of the device.
Oct 02, 2009 | Coby MP-610 MP3 Player
Dvd740 not reading DVD+R disk
It sounds like the drive has failed but before you rip it out and trash it you should check that it is listed in your hardware via control panel , system. If it shows up as fine then try burn somthin simple like a regular CD not dvd. if that works the problem may be with your burning software.
if its not listed in hardware or has an exclamation mark by it the its time to open the computer case and check the connections to the drive. remove each connection one at a time and re-connect before moving onto the next one. switch the computer back on and see if it finds new hardware or shows up fine in your hardware list. If not then it is probably pooched.
Aug 09, 2009 | HP Computers & Internet
Graphics, missing hard and disk drives,
YOUR MAIN BOARD HAS A PROBLEM JUST TAKE TO A APPle service center
Jan 03, 2009 | Apple Computers & Internet
Toshiba MK4034GSX 40 GB SATA Hard Drive Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
