Question about Philips GoGear SA178 MP3 Player
Player problem connect to pc
I am also facing same problem. Please help.
regards,
Vishal
ALQUEM TEM O RESET
Philips gogear model no 1356/97 1gb connect player to pc
Posted on Apr 28, 2008
  • Anonymous Apr 28, 2008
    I AM ALSO FACING SAME PROBLEM . PLEEEASE HELP.
  • 8,596 Answers
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Posted on Apr 08, 2008
SOURCE:
I forget my Nokia 1100 security code how can i reset them please Help me. Vishal
Try master reset codes for your phone here http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/ by the way you can reset the security code and change new
Jan 17, 2011 | Nokia 1100
Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
Aug 09, 2009 | Sony VAIO TR1MP Notebook
Serial number nero bburning rom installation wizard
nero ultra
1C82-0000-19E5-MAAX-4006-3722-9426
nero premium
1C80-0000-19E5-MA2X-4002-4146-4458
nero essentials
5C89-0000-1911-0000-4007-5457-1666
May 11, 2009 | Ahead Software Nero 6.6 (600901) for PC
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Dec 29, 2008 | Sony XPLOD CDX-GT200 CD Player
W230 cant connect to a pc
http://www.cellphone9.com/motorola-w230-file-transfer-problems-firmware-update/
follow the above line.... and probably you must have a memory card in the fone.... once you are done with downloading the driver  connect the fone and you would get the 'found new hardware baloon' select 'no not this time' and click next and browse to the driver which is downloaded, click next and finish the process...
once you remove and connect the fone you would get a prompt on the fone's display "connect phone as storage device" click yes to transfer data or click no or leave it alone for the fone to get charged...
hope this helps you..
use this alt link to download driver
http://direct.motorola.com/hellomoto/in/support/usb_drivers_pc_charging_drivers.asp
incase of any further clarifications  vishal at games.com....
Cheers, vishal...
Nov 12, 2008 | Motorola Mobility W230 Phone US with...
Trenscend T.sonic 610 hung
reset
try reinstalling firmware
battery change
checkout if you can still use it as a simple memory stick
when connected to pc and if checkdisk can format the disk
contact RMA
Dec 30, 2007 | Transcend T.sonic 610 MP3 Player
This is usually caused by corrupt firmware on the player.
Install the Firmware Manager software from the product CD.
Open Firmware Manager and select the repair option.
Dec 17, 2007 | Philips SA1100 MP3 Player
Philips GoGear SA178 MP3 Player Logo
200 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
