Question about LG 42LG50 42 in. LCD HDTV
LG 42LG50 42 in. HDTV LCD TV just hooked digital box to tv , and signal is lost after a while. picture shows audio lost, please help.
  • LG Master
  • 8,457 Answers
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
Posted on May 04, 2010
How can I receive digital signal with this TV
go into settings and click on the recieving button and then click on scanning for channels, make sure it says DIGITAL signals. ...this search could take a 5-10 minutes
May 27, 2014 | LG 37LC2RR 37 in. LCD TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
Jan 16, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
TV shows "No Signal" when hooked to cable. Cable has been tested with another TV and that TV works fine.
hi if you are connecting the cable box through HDMI then you may need to get the lg tech guy's to come out and reprograme the edid data in the HDMI sockets it's a common problem
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
LG 22" Flat Screen HDTV
the Svideo, not Saudio, will have to be selected in the tv's input menu, but Svideo won't give audio, you will have to connect audio leads to the TV and to the sat box or whatever you are using for your programmes
Aug 19, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LG50 42 in. LCD HDTV Logo
456 people viewed this question
Computer Repairing
Computer Repairing
