Question about IOGear ION (GHD335C160) 160 GB Hard Drive
160GB IOMEGA Tri-Select ION Drive. The three blue lights are flashing and my computer doesn't recognize the drive. I've used it with this computer before. What do the flashing blue lights mean?
3 Suggested Answers
SOURCE: My Computer doesn't recognize Ion 320 GB Harddrive w/Tri select
This isn't a solution but might help...
I have the same drive... with mine it recognizes sometimes but usually freezes my computer when I try to write to the drive. I thought it was the actual hard drive, but that works fine when installed in my tower... I now notice that one of the small components, component L14, is actullay missing a corner!!!! Like it chipped off! I'm blaming that. It seems to be part of the usb/firewire section of the mainboard. I'd like to replace it... does anyone know what that component is?
here are some photos:
www.belowmemusic.com/ion
Posted on May 31, 2008
bronk50
  • 27725 Answers
SOURCE: My iomega prestige 1TB hard
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
hope this helps
Posted on Aug 24, 2011
My iomega 1 tb hard drive isn't recognized by computer. Blue light turns on but I don't hear anything from the device itself
What's your operating system? If windows: Check in device manager if its recognized as USB device. You can also look in disk managment
Aug 31, 2013 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
How can I tell if everything is downloaded to my external drive...it was flashing and then stopped to leave a little light on...how can I tell how much memory is left on that external hard drive?
Hello and Good Day!
1.Click Start on the lower corner of your desktop PC go to My Computer. 2. Left Click My Computer using your mouse.(it will pop up new windows) 3.Locate your Hard Drive perhaps it is labeled as IOMEGA or removable drive. 4. Right click IOMEGA or removable drive then select Properties.a new window will pop up displaying a circle with two colors one is pink and other is blue. blue represents as used space and the pink as free space
Hope it helps Thanks!
Jun 10, 2011 | Iomega (33090) 250 GB Hard Drive
My Iomega eGo 500 GB Extern Hard Drive stopped working, it says that USB is not recognized (I tried in 4 pc's) and LED is ON. What can I do to get it back working?
if that happens after trying it on different computers then it means the magnetic needle inside the drive is broken and will need to be replaced.
Feb 25, 2011 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
Iomega isn't recognized on computer. Blue light is flashing on unit as well.
Is this a Windows compute? In case it is, there can be a number of causes, USB, conflicting driver letters, etc. Have a look on this article about how to troubleshoot such problems:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
May 21, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Blue light flashing but imac not recognizing.
Iomega is not a recognized company with Apple and may not be compatible with Macintosh and may be a PC only product.
Jul 21, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Blue light flashed on the portable hard drive for a couple seconds.How do I know if all files were transfered? Nothing on screen showed up? I have a HP laptop.
If your portable hard drive was set up as the "H" drive, go to My Computer (in Windows XP), or Computer (in VISTA), select your "H" drive and view your files (if there).
Jun 10, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Need help to locate Western Digital Passport 160GB External Drive
Could be a hard drive logic board issue since the computer bios recognizes the drive but the computer operating system does not. Not good.
Jun 25, 2017 | Western Digital Passport 160GB External...
Oct 15, 2007 | IOGear ION (GHD335C160) 160 GB Hard Drive
IOGear ION (GHD335C160) 160 GB Hard Drive Logo
438 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
