Question about Epson Stylus CX6600 All-In-One InkJet Printer
Paper feed problem
Papter tears in the centre and refuses to feed. Any suggestions please.
Necessary
Posted on Apr 07, 2008
How do I feed new paper
no need to feed paper simply pull about 3 inches of extra paper from roll, after placing paper in cradle, close the door on the extra paper and tear, this is all no feeding needed
Mar 07, 2014 | VeriFone Retail Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    On "print" command, paper feed
    hi
    you may have something in the paper feed area.. unplug all .. lift printer upside down and shake lightly, see if something is lodged in the paper feed area..
    if this is not the issue, perhaps the roller(s) is off centre and requires adjusting
    send me 4 thumbs up please.
    Jul 20, 2011 | Dell 924 All-in-One InkJet Printer
    I do not nave the manual and am having troble feeding papter
    Slip paper over the back roller and through the open slot on back of fax.
    Feb 11, 2010 | Sharp Televison & Video
    Epson SX5400... accepts regular plain paper just fine but jams with Glossy Photo papter
    That is because you need to change the settings on your printer to the type of paper your using.
    Hope this helps!
    Feb 06, 2010 | Epson Stylus CX5400 All-In-One InkJet...
    My Ip90 won't feed paper when I try to print a job.
    If the paper does not feed properly it could be due to the follwong causes.
    Cause 1 : Inappropriate paper type used
    Action : * Check to see if the paper you are printing on is too thick or curled.
    * Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
    Cause 2 : Paper Feed Roller is dirty.
    Action : Follow the steps described below to clean the Paper Feed Rollers.
    If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
    1) Ensure that the printer is turned on and there is no paper loaded in the printer.
    2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
    The paper roller rotates as it cleans.
    3) Repeat this cleaning operation one more time.
    4) Load a sheet of plain paper in the printer.
    5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
    Cause 3 : Paper jams.
    Action : Remove the paper according to the following procedure.
    1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
    * If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
    Caution: Be careful not to touch any components inside the printer.
    * If you cannot pull the paper out, turn the printer off and turn it on again.
    The paper will be ejected automatically.
    2) Reload the paper into the printer and press the RESUME/ CANCEL button.
    If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
    Hope this helps.
    Please rate my response.
    Thanks
    Have a good day.
    Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
    When printing back side of paper, paper turns sideways and tears in half.
    see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
    Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
    Paper feed jams
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Jan 08, 2009 | HP Photosmart C7280 Laser Printer
    Hi I have a Canon PIXMA MP950 printer , purchased on Dec. 6/05. Yesterday I had paper jams inside the machine. It fed the paper from the cassette, but got stopped on rollers in rear cover area. I can...
    It is fixed, I think. My husband worked on it today and had a look inside the printer with a flashlight. He found a plastic tack had dropped in the rear of the printer, down in the rollers! So he fished it out & we seem to be up & running!
    Thank You! Joann Gabriel
    Nov 12, 2008 | Office Equipment & Supplies
    Epson Stylus CX6600 All-In-One InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
